Function code
Default    value
Modify
P15.00
Module type
0: PROFIBUS;
1: CANopen
Select communication protocol
P15.01
Module address
0–127
This function code is used to designate the address of the VFD.
Note: 0 is the broadcast address, when set it as   broadcast address, only receive the radio command of the upper monitor other   than answering the upper monitor.
P15.02
PZD2 receiving
0: Invalid
1: Setting frequency   (0–Fmax (unit: 0.01 Hz))
2: PID reference,   range (0–1000, 1000 corresponds to 100.0%)
3: PID feedback,   range (0–1000, 1000 corresponds to 100.0%)
4: Torque setting (-3000–3000,   1000 corresponds to 100.0% the rated current of the motor)
5: Upper frequency   of forward rotation
 (0–Fmax unit: 0.01 Hz))
6: Upper frequency   of reverse rotation (0–Fmax (unit: 0.01 Hz))
7: Electromotion   torque upper limit (0–3000, 1000 corresponds to 100.0% of the rated current   of the motor)
8: Brake torque   upper limit (0–2000, 1000 corresponds to 100.0% of the rated current of the   motor)
9: Virtual input   terminals command
Range: 0x000–0x1FF
10: Virtual output   terminals command
Range: 0x00–0x0F
11: Voltage setting   value (special for V/F separation) (0–1000,1000 corresponds to 100.0% the   rated voltage of the motor)
12: AO output set   value 1 (-1000–+1000, 1000 corresponds to 100.0%)
13: AO output set   value 2 (-1000–+1000, 1000 corresponds to 100.0%)
14: MSB of position   reference (signed digit)
15: LSB of position   reference (unsigned digit)
16: MSB of position   feedback (signed digit)
17: LSB of position   feedback (unsigned digit)
18: Position   feedback setting flag (Position feedback can be set only after you set this   flag to 1 first and then set it to 0.)
19–20: Reserved
P15.03
PZD3 receiving
P15.04
PZD4 receiving
P15.05
PZD5 receiving
P15.06
PZD6 receiving
P15.07
PZD7 receiving
P15.08
PZD8 receiving
P15.09
PZD9 receiving
P15.10
PZD10 receiving
P15.11
PZD11 receiving
P15.12
PZD12 receiving
P15.13
PZD2 sending
0: Invalid
1: Running frequency   (*100, Hz)
2: Setting frequency   (*100, Hz)
3: Bus voltage (*10,   V)
4: Output voltage (*1,   V)
5: Output current (*10,   A)
6: Output torque   actual value (*10, %)
7: Output power   actual value (*10, %)
8: Running rotating   speed (*1, RPM)
9: Running linear   speed (*1, m/s)
10: Ramp reference frequency
11: Fault code
12: AI1 value (*100,   V)
13: AI2 value (*100,   V)
14: AI3 value (*100,   V)
15: PULSE frequency   value (*100, kHz)
16: Terminals input   state
17: Terminals output   state
18: PID given (*100,   %)
19: PID feedback (*100,   %)
20: Motor rated   torque
21: MSB of position   reference (signed digit)
22: LSB of position   reference (unsigned digit)
23: MSB of position   feedback (signed digit)
24: LSB of position   feedback (unsigned digit)
25: State   words
P15.14
PZD3 sending
P15.15
PZD4 sending
P15.16
PZD5 sending
P15.17
PZD6 sending
P15.18
PZD7 sending
P15.19
PZD8 sending
P15.20
PZD9 sending
P15.21
PZD10 sending
P15.22
PZD11 sending
P15.23
PZD12 sending
P15.24
Temporary variable 1 for PZD sending
0–65535
P15.25
Fault time of DP communication overtime
0.0 (invalid), 0.1–60.0s
When this function code is set as 0.0, this function is invalid.
When the function code is set as nonzero value, if the internal time   between two communication exceeds the communication overtime, the system will   report "PROFIBUS communication fault" (E-DP).
0.0 s
P15.26
Fault time of CANopen communication   overtime
0.0 (invalid),0.1–60.0   s
When the function code is set as nonzero value, if the internal time   between two communication exceeds the communication overtime, the system will   report "CANopen communication fault" (E-CAN)
0.0 s
P15.27
CANopen baud rate
Set the data   transmission rate.
0: 1000 k
1: 800 k
2: 500 k
3: 250 k
4: 125 k
5: 100 k
6: 50 k
7: 20 k
