If installed in an appropriate environment, the VFD requires very little maintenance. The table lists the routine maintenance intervals recommended by INVT.
Checking
Item
Method
Criterion
Ambient
environment
Check the ambient temperature, humidity and vibration   and ensure there is no dust, gas, oil fog and water drop.
Visual examination
and instrument test
Conforming to the manual
Ensure there are no tools or other foreign or   dangerous objects
Visual examination
There are no tools or dangerous objects.
Voltage
Ensure the main circuit and control circuit are   normal.
Measurement by millimeter
Keypad
Ensure the display is clear enough
Visual examination
The characters are displayed normally.
Ensure the characters are displayed totally
Visual examination
Main
circuit
For public use
Ensure the screws are tightened firmly
Tighten up
NA
Ensure there is no distortion, crackles, damage or   color-changing caused by overheating and aging to the machine and insulator.
Visual examination
NA
Ensure there is no dust and dirtiness
Visual examination
NA
Note: if the color of the copper blocks change, it does   not mean that there is something wrong with the features.
The lead
of the
conductors
Ensure that there is no distortion or   color-changing of the conductors caused by overheating.
Visual examination
NA
Ensure that there are no crackles or   color-changing of the protective layers.
Visual examination
NA
Terminals
seat
Ensure that there is no damage
Visual examination
NA
Filter capacitors
Ensure that there is no weeping, color-changing,   crackles and cassis expansion.
Visual examination
NA
Ensure the safety valve is in the right place.
Estimate the usage time according to the   maintenance or measure the static capacity.
NA
If necessary, measure the static capacity.
Measure the capacity by instruments.
The static capacity is above or equal to the   original value *0.85.
Resistors
Ensure whether there is replacement and splitting   caused by overheating.
Smelling and visual examination
NA
Ensure that there is no offline.
Visual examination or remove one ending to   coagulate or measure with multimeters
The resistors are in ±10% of the standard value.
Transformers
and   reactors
Ensure there is no abnormal vibration, noise and   smelling,
Hearing, smelling and visual examination
NA
Electromag
netism   contactors
and relays
Ensure whether there is vibration noise in the workroom.
Hearing
NA
Ensure the contactor is good enough.
Visual examination
NA
Control circuit
PCB and
plugs
Ensure there are no loose screws and contactors.
Fasten up
NA
Ensure there is no smelling and color-changing.
NA
Ensure there are no crackles, damage distortion   and rust.
Visual examination
NA
Ensure there is no weeping and distortion to the   capacitors.
Visual examination or estimate the usage time   according to the maintenance information
NA
Cooling system
Cooling fan
Estimate whether there is abnormal noise and   vibration.
Hearing and Visual examination or rotate with hand
Stable rotation
Estimate there is no losses screw.
Tighten up
NA
Ensure there is no color-changing caused by   overheating.
NA
Ventilating
duct
Ensure whether there is stuff or foreign objection   in the cooling fan, air vent.
Visual examination
NA
For more information about the maintenance, contact the local INVT office, or visit the website http://www.invt.com.cn of Shenzhen INVT Electric CO., Ltd., choosing Service and Support on the homepage to obtain the online service you need.
