Motor type
Asynchronous induction motor or synchronous   permanent magnet motor
Voltage
0 to U1, 3-phase symmetrical, Umax at the field   weakening point
Short-circuit   protection
The motor output is short-circuit proof by IEC   61800-5-1
Frequency
0–400 Hz
Frequency   resolution
0.01 Hz
Current
Refer to section 3.6 "Rated   values"
Power limit
Field weakening   point
10–400 Hz
Carrier frequency
4, 8, 12 or 15 kHz
B.4.1 EMC compatibility and motor cable length
The following table describes the maximum motor cable lengths that meet the requirements of the EU EMC directive (2004/108/EC) when the carrier frequency is 4 kHz.
All models (with   external EMC filters)
Maximum motor cable length (m)
Environment category II (C3)
30
Environment category I (C2)
30
You can learn the maximum length of the motor cable through the running parameters of the VFD. To understand the accurate maximum cable length for using an external EMC filter, contact the local INVT office.
For description about the environments categories I (C2) and II (C3), see section B.6 "EMC regulations".
