Below is the peripheral wiring of Goodrive35 series VFDs.
1. Built-in brake unit is included for 380 V 30 kW and below models;
2. P1 terminal is included for 380 V 37 kW and above models, which can be connected to external DC reactor directly;
3. P1 terminal is included for 660 V and above models, which can be connected to external DC reactor directly;
4. The brake units INVT's DBU series standard brake units. For details, see the DBU operation manual.
Pictures
Descriptions
Cables
Device to transfer the electronic signals
Breaker
Prevent from electric shock and protect the power   supply and the cables system from overcurrent when short circuits occur. (Please   select the breaker with the function of reducing high order harmonic and the   rated sensitive current to 1 VFD should be above 30mA).
Input reactor
This device is used to improve the power factor of   the input side of the VFD and control thehigher harmonic current.
The VFDs of 380 V (≥37 kW) and of 660 V have   external DC reactors.
DC reactor
Input filter
Control the electromagnetic interference generated   from the VFD, please install close to the input terminal side of the VFD.
Accessory that restricts the electromagnetic   interference generated by the VFD and transmitted to the public grid through   the power cable. Try to install the input filter near the input terminal side   of the VFD.
 or
Brake unit or brake resistors
Accessories used to consume the regenerative   energy of the motor to reduce the deceleration time.
VFDs of 380 V, 30 kW or lower need only to be configured   with brake resistors, those of 380V, 37 kW or higher and 660 V series also   need to be configured with brake units,.
Output filter
Control the interference from the output side of   the VFD and please install close to the output terminals of the VFD.
Output reactor
Prolong the effective transmitting distance of the   VFD to control the sudden high voltage when switching on/off the IGBT of the VFD.
