The keypad is used to control Goodrive300 series VFDs, read the state data and adjust parameters. If you need to use the keypad in another place rather than on the VFD, use a network cable with a standard RJ45 crystal head as the extension cable.
Figure 5-1 Keypad
1. The LED keypad is standard but the LCD keypad which can support various languages, parameters copy and 10-line displaying is optional.
2. It is necessary to use M3 screw or installation bracket to fix the external keypad. The installation bracket for VFDs of 380V 1.5–30kW and 500V 4–18.5kW is optional but it is standard for the VFDs of 380V 37–500kW, 500V 22–75kW and 660V.
No.
Description
State
LED
RUN/TUNE
LED off means that the VFD is in the stopping state; LED blinking   means the VFD is in the parameter autotune state; LED on means the VFD is in   the running state.
FWD/REV
FED/REV LED
LED off means the VFD is in the forward rotation state; LED on means   the VFD is in the reverse rotation state
LOCAL/REMOT
LED for keypad operation, terminals operation and remote communication control
LED off means that the VFD is in the keypad operation state; LED   blinking means the VFD is in the terminals operation state; LED on means the VFD   is in the remote communication control state.
TRIP
LED for faults
LED on when the VFD is in the fault state; LED off in normal state;   LED blinking means the VFD is in the pre-alarm state.
Unit
LED
Mean the unit displayed currently
Hz
Frequency unit
A
Current unit
V
Voltage unit
RPM
Rotating speed unit
Percentage
3
Code
 displa-
ying
 zone
5-figure LED display displays various monitoring data and alarm code such as set frequency and output frequency.
4
Digital potent-iometer
Tuning frequency. Please refer   to P08.41.
5
Buttons
Progra-mming key
Enter or escape from the first level menu and remove the parameter quickly.
Entry key
Enter the menu step-by-step
Confirm parameters.
UP key
Increase data or function code   progressively.
DOWN key
Decrease data or function code   progressively.
Right-shift key
Move right to select the   displaying parameter circularly in stopping and running mode.
Select the parameter modifying   digit during the parameter modification.
Run key
This key is used to operate on the VFD in key operation mode.
Stop/
Reset key
This key is used to stop in running state and it is limited by function   code   P07.04
This key is used to reset all control modes in the fault alarm state.
Quick key
The function of this key is confirmed by function code P07.02.
