When the voltage of the grid is high, the transient large current that flows into the input power circuit may damage rectifier components. You need to configure an AC reactor on the input side, which can also improve the current adjustment coefficient on the input side.
When the distance between the VFD and motor is longer than 50 m, the parasitic capacitance between the long cable and ground may cause large leakage current, and overcurrent protection of the VFD may be frequently triggered. To prevent this from happening and avoid damage to the motor insulator, compensation must be made by adding an output reactor. When a VFD is used to drive multiple motors, take the total length of the motor cables (that is, sum of the lengths of the motor cables) into account. When the total length is longer than 50 m, an output reactor must be added on the output side of the VFD. If the distance between the VFD and motor is 50 m to 100 m, select the reactor according to the following table. If the distance is longer than 100 m, contact INVT's technical support technicians.
The VFDs of 380V (≥37Kw), 500V (≥22Kw) and of 660V are equipped with internal DC reactors for the improvement of power factors and the avoidance of damage from high input current to the rectifying components because of the high-capacity transformer. The device can also cease the damage to the rectifying components which are caused by supply net voltage transients and harmonic waves of the loads.
image.pngD.6.1 AC 3PH 380V(-15%)–440V(+10%)
Model
Input    reactor
DC    reactor
Output    reactor
GD300-1R5G-4
ACL2-1R5-4
OCL2-1R5-4
GD300-2R2G-4
ACL2-2R2-4
OCL2-2R2-4
GD300-004G-4
ACL2-004-4
OCL2-004-4
GD300-5R5G-4
ACL2-5R5-4
OCL2-5R5-4
GD300-7R5G-4
ACL2-7R5-4
OCL2-7R5-4
GD300-011G-4
ACL2-011-4
OCL2-011-4
GD300-015G-4
ACL2-015-4
OCL2-015-4
GD300-018G-4
ACL2-018-4
OCL2-018-4
GD300-022G-4
ACL2-022-4
OCL2-022-4
GD300-030G-4
ACL2-030-4
OCL2-030-4
GD300-037G-4
ACL2-037-4
DCL2-037-4
OCL2-037-4
GD300-045G-4
ACL2-045-4
DCL2-045-4
OCL2-045-4
GD300-055G-4
ACL2-055-4
DCL2-055-4
OCL2-055-4
GD300-075G-4
ACL2-075-4
DCL2-075-4
OCL2-075-4
GD300-090G-4
ACL2-110-4
DCL2-090-4
OCL2-110-4
GD300-110G-4
ACL2-110-4
DCL2-132-4
OCL2-110-4
GD300-132G-4
ACL2-132-4
DCL2-132-4
OCL2-132-4
GD300-160G-4
ACL2-160-4
DCL2-160-4
OCL2-160-4
GD300-200G-4
ACL2-200-4
DCL2-220-4
OCL2-200-4
GD300-220G-4
ACL2-250-4
DCL2-220-4
OCL2-250-4
GD300-250G-4
ACL2-250-4
DCL2-280-4
OCL2-250-4
GD300-280G-4
ACL2-280-4
DCL2-280-4
OCL2-280-4
GD300-315G-4
ACL2-315-4
DCL2-315-4
OCL2-315-4
GD300-350G-4
Standard
DCL2-400-4
OCL2-350-4
GD300-400G-4
Standard
DCL2-400-4
OCL2-400-4
GD300-500G-4
Standard
DCL2-500-4
OCL2-500-4
1. The rated derate voltage of the input reactor is 2%±15%.
2. The power factor of the input side is above 90% after installing DC reactor.
3. The rated derate voltage of the output reactor is 1%±15%.
4. Above options are external, the customer should indicate when purchasing.
D.6.2 AC 3PH 380V(-10%)V–550V(+10%)
Model
Input    reactor
DC    reactor
Output    reactor
GD300-004G-5
GD300-5R5G-5
GD300-7R5G-5
GD300-011G-5
GD300-015G-5
ACL2-030-6
OCL2-030-6
GD300-018G-5
ACL2-030-6
OCL2-030-6
GD300-022G-5
ACL2-055-6
DCL2-055-6
OCL2-055-6
GD300-030G-5
ACL2-055-6
DCL2-055-6
OCL2-055-6
GD300-037G-5
ACL2-110-6
DCL2-110-6
OCL2-110-6
GD300-045G-5
ACL2-110-6
DCL2-110-6
OCL2-110-6
GD300-055G-5
ACL2-110-6
DCL2-110-6
OCL2-110-6
GD300-075G-5
ACL2-110-6
DCL2-110-6
OCL2-110-6
D.6.3 AC 3PH 520V(-15%)–690V(+10%)
Model
Input    reactor
DC    reactor
Output    reactor
GD300-022G-6
ACL2-030-6
DCL2-030-6
OCL2-030-6
GD300-030G-6
ACL2-030-6
DCL2-030-6
OCL2-030-6
GD300-037G-6
ACL2-055-6
DCL2-055-6
OCL2-055-6
GD300-045G-6
ACL2-055-6
DCL2-055-6
OCL2-055-6
GD300-055G-6
ACL2-055-6
DCL2-055-6
OCL2-055-6
GD300-075G-6
ACL2-110-6
DCL2-110-6
OCL2-110-6
GD300-090G-6
ACL2-110-6
DCL2-110-6
OCL2-110-6
GD300-110G-6
ACL2-110-6
DCL2-110-6
OCL2-110-6
GD300-132G-6
ACL2-185-6
DCL2-185-6
OCL2-185-6
GD300-160G-6
ACL2-185-6
DCL2-185-6
OCL2-185-6
GD300-185G-6
ACL2-185-6
DCL2-185-6
OCL2-185-6
GD300-200G-6
ACL2-250-6
DCL2-250-6
OCL2-250-6
GD300-220G-6
ACL2-250-6
DCL2-250-6
OCL2-250-6
GD300-250G-6
ACL2-250-6
DCL2-250-6
OCL2-250-6
GD300-280G-6
ACL2-350-6
DCL2-350-6
OCL2-350-6
GD300-315G-6
ACL2-350-6
DCL2-350-6
OCL2-350-6
GD300-350G-6
ACL2-350-6
DCL2-350-6
OCL2-350-6
GD300-400G-6
Standard
DCL2-400-6
OCL2-400-6
GD300-500G-6
Standard
DCL2-560-6
OCL2-560-6
GD300-560G-6
Standard
DCL2-560-6
OCL2-560-6
GD300-630G-6
Standard
DCL2-630-6
OCL2-630-6
