Check as follows after the installation:
1. Check that the load range of the input and output cables meet the need of actual load. |
2. Check that the accessories of the VFD are correctly and properly installed. The installation cables should meet the needs of every component (including reactors, input filters, output reactors, output filters, DC reactors, braking units and braking resistors). |
3. Check that the VFD is installed on non-flammable materials and the calorific accessories (reactors and brake resistors) are away from flammable materials. |
4. Check that all control cables and power cables are run separately and the routing complies with EMC requirement. |
5. Check that all grounding systems are properly grounded according to the requirements of the VFD. |
6. Check that the free space during installation is sufficient according to the instructions in user’s manual. |
7. Check that the installation conforms to the instructions in user’s manual. The drive must be installed in an upright position. |
8. Check that the external connection terminals are tightly fastened and the torque is appropriate. |
9. Check that there are no screws, cables and other conductive items left in the VFD. If not, get them out. |
