The keypad is used to control Goodrive310-UL series VFDs, read the state data and adjust parameters.
Figure 5-1 Keypad
1. The LED keypad is standard but the LCD keypad which can support various languages, parameters copy and 10-line displaying is optional.
2. It is necessary to use M3 screw or installation bracket to fix the external keypad. The installation bracket for VFDs of 220V 0.75–15kW and 460V G-type 1.5–30kW, P-type 5.5–37kW is optional but it is standard for the VFDs of 460V G-type 37–500kW, P-type 45–500kW and 575V.
No.
Description
State LED
RUN/TUNE
LED off means that the VFD is in the stopping state; LED blinking means the VFD is in the parameter autotune state; LED on means the VFD is in the running state.
FWD/REV
FED/REV LED
LED off means the VFD is in the forward rotation state; LED on means the VFD is in the reverse rotation state
LOCAL/REMOT
LED for keypad operation, terminals operation and remote   communication control
LED off means that the VFD is in the keypad operation state; LED blinking means the VFD is in the terminals operation state; LED on   means the VFD is in the remote communication control state.
TRIP
LED for faults
LED on when the VFD is in the fault state; LED off in normal state; LED blinking means the VFD is in the pre-alarm state.
Unit LED
Mean the unit displayed currently
Hz
Frequency unit
RPM
Rotating speed unit
A
Current unit
Percentage
V
Voltage unit
3
Code   displaying zone
5-figure LED display displays various   monitoring data and alarm code such as set frequency and output frequency.
4
Digital   potentiometer
Tuning frequency. Please   refer to P08.41.
5
Buttons
Programming key
Enter or escape from the first level menu and remove the parameter quickly
Entry key
Enter the   menu step-by-step
Confirm parameters
UP key
Increase data or function code progressively
DOWN key
Decrease data or function code progressively
Right-shift key
Move right to select the displaying parameter circularly in stopping and running mode.
Select the parameter modifying digit during the parameter modification
Run key
This key is used to operate on the VFD in key operation mode
Stop/
Reset key
This key is used to stop in running state and it is limited by function code P07.04
This key is used to reset all control modes in the fault alarm state
Quick key
The function of this key is confirmed by function code P07.02.
