Check the following before applying the VFD.
l Check   the load type to verify that there is no overload of the VFD during work and   check whether the power class of the VFD needs to be increased.
l Check whether the actual running current of the motor is less than   the rated current of the VFD.
l Check whether the control accuracy required by the load is the   same of the VFD.
l Check whether the grid voltage is consistent with the rated   voltage of the VFD.
l Check whether expansion card are needed for selected functions.
