Complete the basic commissioning as follows before the actual use of the VFD:
l According   to the actual motor parameters, select the motor type, set motor parameters,   and select the VFD control mode.
l Autotune.   If possible, de-couple the VFD from the motor load to start dynamic   autotuning. If the VFD cannot be de-coupled from the load, perform static   autotuning.
l Adjust   the ACC/DEC time according to the actual work condition of the load.
l Perform   device commissioning by means of jogging and check whether the motor   rotational direction is correct. If not, change the rotation direction by   swapping any two phase wires of the motor.
l Set all   control parameters and then operate.
