Function
Specification
Power input
Input voltage (V)
AC 3PH 380V (-15%) -440V (+10%)
Input current (A)
Refer to the rated value
Input frequency (Hz)
50Hz or 60Hz
Allowed range: 47–63Hz
Power factor (%)
≥0.99
Input current harmonic
<5%
Power output
Output voltage (V)
0–Input voltage
Output current (A)
Output power (kW)
Output frequency (Hz)
0–400Hz
Rectification control
Bus voltage detection accuracy
±1% of the overvoltage point
Input current detection accuracy
±3% of the rated input current
Energy feedback
Capable to automatically provide energy feedback to the grid when the bus voltage increases
Overload capability
150% of rated current: 1 minute
180% of rated current: 10 seconds
200% of rated current: 1 second
Converting control
Control mode
SVPWM, sensorless vector control
Motor type
Asynchronous motor
Adjustable-speed ratio
1:200 (SVC)
Speed control accuracy
±0.2% (sensorless vector control)
Speed fluctuation
± 0.3% (sensorless vector control)
Torque response
<20ms (sensorless vector control)
Starting torque
0.25Hz/150% (sensorless vector control)
Overload capability
Running control
Frequency setting method
Digital setting, analog setting, multi-step speed running setting, and Modbus communication setting, which allows setting combination and switch between setting channels
Voltage auto-adjustment
Constant voltage output kept during grid voltage transient
Fault protection
More than 30 protection functions against faults such as overcurrent, overvoltage, undervoltage, overheating, phase loss, underload, and overload
Others
Mounting method
Wall mounting
Running environment temperature
-10–50°C; derated if the temperature exceeds 40°C
Protective degree
IP20
Cooling method
Forced air cooling
