Complete the basic commissioning as followings before actual utilization:
1. Select the motor type, set correct motor   parameters and select control mode of the VFD according to the actual motor   parameters.
2. Autotune. If possible, de-coupled from the   motor load to start dynamic autotune. Or if not, static autotune is   available.
3. Adjust the ACC/DEC time according to the actual   running of the load.
4. Commission the device via jogging and check   that the rotation direction is as required. If not, change the rotation   direction by changing the wiring of motor.
5. Set all control parameters and then operate.
