The keypad is used to control Goodrive35 series VFDs, read the state data, and modify parameters. If you need to use the keypad in another place rather than on the VFD, use a network cable with a standard RJ45 crystal head as the extension cable.
Figure 5‑1 Keypad
1. The LED keypad is standard but the LCD keypad which can support various languages, parameters copy, 10-line displaying is optional and its installation dimension is compatible with the LED keypad.
2. It is necessary to use M3 screw or installation bracket to fix the external keypad. The installation bracket for VFDs of 380 V 1.5–30 kW is optional but it is standard for the VFDs of 380 V 37–500 kW and the VFDs of 660 V.
No.
Description
State
 LED
RUN/TUNE
LED off means that the VFD is in the stopping   state; LED blinking means the VFD is in the parameter autotune state; LED on   means the VFD is in the running state.
FWD/REV
FED/REV LED
LED off means the VFD is in the forward   rotation state; LED on means the VFD is in the reverse rotation state
LOCAL/REMOT
LED for keypad operation, terminals operation   and remote communication control
LED off means that the VFD is in the keypad   operation state; LED blinking means the VFD is in the terminals operation   state; LED on means the VFD is in the remote communication control state.
TRIP
LED for faults
LED on when the VFD is in the fault state; LED   off in normal state; LED blinking means the VFD is in the pre-alarm state.
Unit
 LED
Mean the unit displayed currently
 Hz
Frequency   unit
RPM
Rotating speed unit
A
Current   unit
Percentage
V
Voltage unit
3
Code
displa-
ying
 zone
5-figure LED display displays various monitoring data   and alarm code such as set frequency and output frequency.
4
Digital   potent-iometer
Tuning frequency. Please refer to P08.42.
5
Buttons
Program-
ming key
Enter or escape from the first level menu and remove the parameter   quickly
Entry key
Enter the menu step-by-step
Confirm parameters
UP key
Increase data or function code progressively
DOWN key
Decrease data or function code progressively
Right-
shift
key
Move right to select the displaying parameter   circularly in stopping and running mode.
Select the parameter modifying digit during the   parameter modification
Run key
This key is used to   operate on the VFD in key operation mode
Stop/
Reset key
This key is used to   stop in running state and it is limited by function code P07.04
This key is used to   reset all control modes in the fault alarm state
Quick key
The function of this   key is confirmed by function code P07.02.
