Function code
Default    value
Modify
P08.00
ACC time 2
For detailed definition, see the description of P00.11 and P00.12.
Four groups of ACC and DEC time are defined for the Goodrive35 series.   You can set the ACC and DEC time through the corresponding multi-function   digital input terminals (in the P05 group). For the Goodrive35 series VFD,   the default setting is the first group of ACC and DEC time.
Setting range: 0.0–3600.0s
Depend on model
P08.01
DEC time 2
Depend on model
P08.02
ACC time 3
Depend on model
P08.03
DEC time 3
Depend on model
P08.04
ACC time 4
Depend on model
P08.05
DEC time 4
Depend on model
P08.06
Jogging frequency
This parameter is   used to set the reference frequency of the VFD during jogging.
Setting range: 0.00   Hz–P00.03 (max. output frequency)
5.00 Hz
P08.07
Jogging ACC time
P08.07 indicates the time the VFD takes to accelerate   from 0 Hz to P00.03 (max. output frequency).
P08.08 indicates   the time the VFD takes to decelerate from P00.03 (max. output frequency) to 0 Hz.
Depend on model
P08.08
Jogging DEC time
Depend on model
P08.09
Jumping frequency 1
When the set   frequency is in the range of jumping frequency, the VFD will run at the edge   of the jumping frequency.
The VFD can avoid   the mechanical resonance point by setting the jumping frequency. The VFD can   set three jumping frequency. But this function will be invalid if all jumping   points are 0.
0.00 Hz
P08.10
Jumping frequency range 1
0.00 Hz
P08.11
Jumping frequency 2
0.00 Hz
P08.12
Jumping frequency range 2
0.00 Hz
P08.13
Jumping frequency 3
0.00 Hz
P08.14
Jumping frequency range 3
0.00 Hz
P08.15
Overvoltage stall modulator gain
Setting range: 0.0–1000.0
12.0
P08.16
ASR differential gain
Setting range: 0.00–10.00s
0.00 s
P08.17
Max torque of inertia compensation
Limit the max. inertia   compensation torque to prevent the inertia compensation torque from being too   large.
Setting range: 0.0–150.0%   (rated torque of the motor)
20.0%
P08.18
Inertia compensation filter times
Filter times of   inertia compensation torque is used to smooth the inertia compensation torque.
Setting range: 0–10
7
P08.19
High-frequency ACR   proportional coefficient
In the closed-loop vector control mode (P00.00=3), when the running   frequency is lower than the ACR high frequency switching point (P08.21), the   ACR PI parameters are P03.09 and P03.10; and when the running frequency is   higher than the ACR high frequency switching point, the ACR PI parameters are   P08.19 and P08.20.
Setting range of P08.19: 0–20000
Setting range of P08.20: 0–20000
Setting range   of P08.21: 0.0–100.0% (relative   max frequency)
1000
P08.20
High-frequency ACR   integral coefficient
1000
P08.21
100.0%
P08.22
Inertia identification   torque
Because of the   friction, it is necessary to set identification torque for normal inertia   identification.
0.0–100.0% (rated torque of the motor)
10.0%
P08.23
0: No   operation
1: Starting   identification: press "RUN" to enter into the program after   starting identification until display "-END-"; the identified   system inertia is saved in P08.24.
P08.24
System inertia
The identified   system inertia can be set manually when the system inertia is known. The   displayed system inertia may be less than 0.001kgm2 for the motors   below 1 kW.
Setting range: 0.000–30.000   kgm2
0.000 kgm2
P08.25
Inertia compensation enabled
Identifying the   system inertia correctly and enabling the inertia compensation can improve   the dynamic response of the system.
0: Enabled
1: Disabled
P08.26
Stopping protection for undervoltage
Ones: Enabling
0: Disabled
1: Enabled
Tens: Voltage   selection
0: Internal setting
1: P8.27   setting
After the valid   undervoltage stopping, the VFD will decelerate to stop according to the DEC time   set by P08.05.
0x00
P08.27
Stopping voltage for undervoltage
Setting range: 250.0–1000.0   V
450.0 V
P08.28
Automatic fault reset times
Automatic fault reset times: When the VFD selects automatic fault   reset, it is used to set the times of automatic reset, if the continuous   reset times exceeds the value set by P08.28, the VFD will report fault and   stop to wait for repair.
Interval of automatic fault reset: Select the interval time from when   fault occurred to automatic fault reset actions.
After VFD starts, if no fault occurred during 60s, the fault reset   times will be zeroed out.
Setting   range of P08.28:   0–10
Setting range of P08.29: 0.1–3600.0s
P08.29
Interval time of automatic fault reset
1.0 s
P08.30
Frequency decreasing ratio of the dropping   control
The output frequency   of the VFD changes as the load. And it is mainly used to balance the power   when several VFDs drive one load.
Setting range: 0.00–50.00   Hz
0.00 Hz
P08.31
Motor shifting
Goodrive35 supports the shift between two motors.   This function is used to select the shifting channel.
LED ones: shifting channel
0: Terminal shifting; digital terminal is 35
1: Modbus communication shifting
2: PROFIBUS/CANopen communication shifting
P08.32
FDT1 electrical level detection value
When the output frequency exceeds the   corresponding frequency of FDT electrical level, the multi-function   digital output terminals will output the signal of "frequency level   detect FDT" until the output frequency decreases to a   value lower than (FDT electrical level—FDT retention detection value) the   corresponding frequency, the signal is invalid. Below is the waveform diagram:
Setting range of P08.32:   0.00 Hz–P00.03 (max. output frequency)
Setting range of P08.33:   -200.0–100.0% (FDT1 electrical level)
Setting range of P08.34:   0.00 Hz–P00.03 (max. output frequency)
Setting range of P08.35:   -200.0–100.0% (FDT2 electrical level)
50.00 Hz
P08.33
FDT1 retention   detection value
5.0%
P08.34
FDT2 electrical level detection value
50.00 Hz
P08.35
FDT2 retention   detection value
5.0%
P08.36
Amplitude value for frequency arrival   detection
When the output frequency is among the positive or   negative detection range of the set frequency, the multi-function digital   output terminal will output the signal of "frequency arrival", see   the diagram below for detailed information:
The setting range: 0.00   Hz–P00.03 (max. output frequency)
0.00 Hz
P08.37
Energy brake enable
This parameter is   used to control the internal brake pipe inside the VFD.
0: Disable
1: Enable
Note: Only   applied to internal brake pipe.
P08.38
Threshold voltage of dynamic brake
Set the starting bus voltage of dynamic brake,   adjust this value properly to brake the load effectively. The default value   changes with voltage level
Setting range: 200.0–2000.0 V
380 V voltage:
700.0 V
660 V voltage:
1120.0 V
P08.39
Cooling fan running mode
0: Normal mode
1: The fan keeps   running after power on
P08.40
PWM selection
0x000–0x111
LED ones: PWM mode   setting
0: PWM mode 1, 3PH   and 2PH modulation
1: PWM mode 2, 3PH   modulation
LED tens: Low-speed   carrier frequency limiting mode
0: Reducing the   carrier frequency at low speed, limiting the carrier frequency to 4 kHz when   the machine runs at low speed. This mode is valid only for the closed-loop   vector mode (P00.00=3).
1: No reducing the   carrier frequency at low speed
Hundreds place:   Dead-zone compensation method setting
0: Method   1
1: Method 2
0x001
P08.41
Overmodulation
0x00–0x91
Ones: Overmodulation   selection
0: Invalid
1: Valid
Tens: Heavy overmodulation   factor
0–9
0x01
P08.42
Keypad data control
0x000–0x1223
LED ones: Frequency enable   selection
0: Both ∧/∨ keys and digital potentiometer adjustments are valid
1: Only ∧/∨ keys adjustment is valid
2: Only digital potentiometer adjustments is valid
3: Neither ∧/∨ keys nor   digital potentiometer adjustments are valid
LED tens: Frequency control   selection
0: Only valid when P00.06=0 or P00.07=0
1: Valid for all frequency setting manner
2: Invalid for multi-step speed when multi-step speed   has the priority
LED hundreds: Action   selection during stopping
0: Setting is valid
1: Valid during   running, cleared after stopping
2: Valid during   running, cleared after receiving the stop command
LED thousands: ∧/∨ keys and digital potentiometer integral function
0: The integral   function is valid
1: The integral   function is invalid
0x0000
P08.43
Integral ratio of keypad   potentiometer
0.01–10.00 s
0.10 Hz/s
P08.44
UP/DOWN terminals   control
0x000–0x221
LED ones: frequency   control selection
0: UP/DOWN terminals setting valid
1: UP/DOWN terminals setting valid
LED tens: frequency   control selection
1: All frequency   means are valid
2: When the   multi-step are priority, it is invalid to the multi-step
LED hundreds: action   selection when stop
0: Setting valid
1: Valid in the   running, clear after stop
2: Valid in the   running, clear after receiving the stop commands
0x000
P08.45
UP terminals frequency changing ratio
0.01–50.00 Hz/s
0.50 Hz/s
P08.46
DOWN terminals frequency changing ratio
0.01–50.00 Hz/s
0.50 Hz/s
P08.47
Frequency setting at power loss
0x000–0x121
LED ones: Action   selection when power off.
0: Save when power   off
1: Clear when power   off
LED tens: Action   selection when Modbus set frequency off
2: Clear when stop
LED hundreds: The   action selection when other frequency set frequency off
0x000
P08.48
MSB of initial power consumption
This parameter is   used to set the original value of the power consumption.
The original value   of the power consumption =P08.48*1000+ P08.49
Setting range of P08.48:   0–59999 kWh (k)
Setting range of P08.49:   0.0–999.9 kWh
0°
P08.49
LSB of initial power consumption
0.0°
P08.50
Magnetic flux brake
This function code   is used to enable magnetic flux.
0: Invalid.
100–150: The bigger   the coefficient, the stronger the brake is.
This VFD is used to   increase the magnetic flux to decelerate the motor. The energy generated by   the motor during brake can be converted into heat energy by increasing the   magnetic flux.
The VFD monitors the   state of the motor continuously even during the magnetic flux period. So the   magnetic flux can be used in the motor stop, as well as to change the   rotation speed of the motor. Its other advantages are:
Brake immediately   after the stop command. It does not need to wait the magnetic flux weaken.
Better cooling for   motors. The current of the stator other than the rotor increases during   magnetic flux brake, while the cooling of the stator is more effective than   the rotor.
P08.51
Current regulation coefficient on input   side
This function code   is used to adjust the displayed current of the AC input side.
Setting range: 0.00–1.00
0.56
