Function code
Default    value
Modify
P07.00
User’s password
0–65535
The   password protection will be valid when setting any non-zero number.
00000: Clear   the previous user’s password, and make the password protection invalid.
After the   set user’s password becomes valid, if the password is incorrect, users cannot   enter the parameter menu. Only correct password can make the user check or   modify the parameters. Please remember all users’ passwords.
Retreat   editing state of the function codes and the password protection will become   valid in minute. If the valid password is available, press PRG/ESC   to enter into the editing state of the function codes, and then "0.0.0.0.0"   will be displayed. Unless input right password, the operator cannot enter   into it.
Note: Restoring to the   default value can clear the password, please use it with caution.
P07.01
Parameter copy
The function code determines the manner of   parameters copy.
0: No operation
1: Upload the local function parameter to   the keypad
2: Download the keypad function parameter   to local address (including the motor parameters)
3: Download the keypad function parameter   to local address (excluding the motor parameter of P02 and P12 group)
4: Download the keypad function parameters   to local address (only for the motor parameter of P02 and P12 group)
Note: After   completing the 1–4 operations, the parameter will come back to 0 automatically;   the function of upload and download excludes the factory parameters of P29.
P07.02
QUICK/JOG function selection
0: No function
1: Jogging. Press QUICK/JOG to begin the   jogging running.
2: Shift the display state by the shifting   key. Press QUICK/JOG to shift   the displayed function code from right to left.
3: Shift between forward rotations and   reverse rotations. Press QUICK/JOG to shift the   direction of the frequency commands. This function is only valid in the   keypad commands channels.
4: Clear UP/DOWN settings. Press QUICK/JOG   to clear the set value of UP/DOWN.
5: Coast to stop. Press QUICK/JOG   to coast to stop.
6: Shift the given manner of running   commands. Press QUICK/JOG to shift the given manner of   running commands.
7: Quick commission mode (commission   according to the non-factory parameter)
Note: Press QUICK/JOG to shift   between forward rotation and reverse rotation, the VFD does not remember the   state after shifting during powering off. The VFD will run in the running   direction set according to parameter P00.13 during next powering on.
P07.03
Shifting sequence selection ofQUICK/JOG   commands
When P07.06=6, set the shifting sequence of   running command channels.
0: Keypad control→terminals control   →communication control
1: Keypad control←→terminals control
2: Keypad control←→communication control
3: Terminals control←→communication control
P07.04
STOP/RST stop function
STOP/RST is valid for stop function. STOP/RST   is valid in any state for the fault reset.
0: Only valid for the keypad control
1: Both valid for keypad and terminals   control
2: Both valid for keypad and communication   control
3: Valid for all control modes
P07.05
Parameters state 1
0x0000–0xFFFF
BIT0: Running frequency (Hz on)
BIT1: Set frequency (Hz flickering)
BIT2: Bus voltage (Hz on)
BIT3: Output voltage (V on)
BIT4: Output current (A on)
BIT5: Running rotation speed (rpm on)
BIT6: Output power (% on)
BIT7: Output torque (% on)
BIT8: PID reference (% flickering)
BIT9: PID feedback value (% on)
BIT10: Input terminals state
BIT11: Output terminals state
BIT12: Torque set value (% on)
BIT13: Pulse counter value
BIT14: Length value
BIT15: PLC and the current stage in multi-step   speed
0x03FF
P07.06
Parameters state 2
0x0000–0xFFFF
BIT0: AI1 (V on)
BIT1: AI2 (V on)
BIT2: AI3 (V on)
BIT3: HDI frequency
BIT4: Motor overload percentage (% on)
BIT5: VFD overload percentage (% on)
BIT6: Ramp frequency given value (Hz on)
BIT7: Linear speed
BIT8: AC inlet current (A on)
BIT9–15: Reserved
0x0000
P07.07
Parameters for stopping state
0x0000–0xFFFF
BIT0: Set frequency (Hz on, frequency   flickering slowly)
BIT1: Bus voltage (V on)
BIT2: Input terminals state
BIT3: Output terminals state
BIT4: PID reference (% flickering)
BIT5: PID feedback value (% flickering)
BIT6: Torque reference (% flickering)
BIT7: AI1 (V on)
BIT8: AI2 (V on)
BIT9: AI3 (V on)
BIT10: HDI frequency
BIT11: PLC and the current stage in multi-step   speed
BIT12: Pulse counters
BIT13: Length value
BIT14–BIT15: Reserved
0x00FF
P07.08
Frequency coefficient
0.01–10.00
Displayed frequency=running frequency*   P07.08
1.00
P07.09
Rotation speed coefficient
0.1–999.9%
Mechanical rotation speed =120*displayed   running frequency×P07.09/motor pole pairs
100.0%
P07.10
Linear speed coefficient
0.1–999.9%
Linear speed= Mechanical rotation speed×P07.10
1.0%
P07.11
Rectifier bridge module temperature
-20.0–120.0°C
P07.12
Inverter module temperature
-20.0–120.0°C
P07.13
Software version
1.00–655.35
P07.14
Local accumulative running time
0–65535h
P07.15
MSB of power consumption
Display the power used by the VFD.
The power consumption of the VFD =P07.15*1000+P07.16
Setting range of P07.15: 0–65535 kWh (*1000)
Setting range of P07.16: 0.0–999.9 kWh
P07.16
LSB of power consumption
P07.17
Reserved
Reserved
P07.18
Rated VFD power
0.4–3000.0 kW
P07.19
Rated VFD voltage
50–1200 V
P07.20
Rated VFD current
0.1–6000.0A
P07.21
Factory barcode 1
0x0000–0xFFFF
P07.22
Factory barcode 2
0x0000–0xFFFF
P07.23
Factory barcode 3
0x0000–0xFFFF
P07.24
Factory barcode 4
0x0000–0xFFFF
P07.25
Factory barcode 5
0x0000–0xFFFF
P07.26
Factory barcode 6
0x0000–0xFFFF
P07.27
Current fault type
0: No fault
1: Inverter unit U phase protection (OUt1)
2: Inverter unit V phase protection (OUt2)
3: Inverter unit W phase protection (OUt3)
4: ACC   overcurrent (OC1)
5: DEC   overcurrent (OC2)
6:   Constant-speed overcurrent (OC3)
7: ACC   overvoltage (OV1)
8: DEC   overvoltage (OV2)
9:   Constant-speed overvoltage (OV3)
10: Bus undervoltage (UV)
11: Motor overload (OL1)
12: VFD overload (OL2)
13: Input side phase loss (SPI)
14: Output side phase loss (SPO)
15: Overheat of the rectifier module (OH1)
16: Overheat   fault of the inverter module (OH2)
17: External fault (EF)
18: 485 communication fault (CE)
19: Current detection fault (ItE)
20: Motor autotune fault (tE)
21: EEPROM operation fault (EEP)
22: PID response offline fault (PIDE)
23: Brake unit fault (bCE)
24: Running time arrival (END)
25: Electrical overload (OL3)
26: Panel communication fault (PCE)
27: Parameter uploading fault (UPE)
28: Parameter downloading fault (DNE)
29: PROFIBUS communication fault (E-DP)
30: Ethernet communication fault (E-NET)
31: CANopen communication fault (E-CAN)
32: Grounding short circuit fault 1 (ETH1)
33: Grounding short circuit fault 2 (ETH2)
34: Speed deviation fault (dEu)
35: Maladjustment (STu)
36: Undervoltage fault (LL)
37: Encoder offline fault (ENC1O)
38: Encoder reverse fault (ENC1D)
39: Encoder pulse Z offline fault (ENC1Z)
43: Motor overtemperature fault (OT)
P07.28
Type of the last fault
P07.29
Type of the last but one fault
P07.30
Type of the last but two fault
P07.31
Type of the last but three fault
P07.32
Type of the last but four fault
P07.33
Running frequency at present fault
0.00 Hz
P07.34
Ramp reference frequency at present fault
0.00 Hz
P07.35
Output voltage at present fault
0 V
P07.36
Output current at present fault
0.0 A
P07.37
Bus voltage at present fault
0.0 V
P07.38
Max temperature at present fault
0.0°C
P07.39
Input terminal state at present fault
P07.40
Output terminal state at present fault
P07.41
Running frequency at last fault
0.00 Hz
P07.42
Ramp reference frequency at last fault
0.00 Hz
P07.43
Output voltage at last fault
0 V
P07.44
Output current at last fault
0.0 A
P07.45
Bus voltage at last fault
0.0 V
P07.46
Max temperature at last fault
0.0°C
P07.47
Input terminals state at last fault
P07.48
Output terminal state at last fault
P07.49
Running frequency at last but one fault
0.00 Hz
P07.50
Output voltage at last but one fault
0.00 Hz
P07.51
Output current at last but one fault
0 V
P07.52
0.0 A
P07.53
Bus voltage at last but one fault
0.0 V
P07.54
Highest temperature at last but one fault
0.0°C
P07.55
Input terminal state at last but one fault
P07.56
Output terminal state at last but one fault
