Function code
Default    value
Modify
P06.00
HDO output
The function selection of the high-speed pulse   output terminals.
0: Open collector pole high speed pulse output:   The Max pulse frequency is 50.0 kHz. See P06.27–P06.31 for detailed   information of the related functions.
1: Open collector pole output. See P06.02   for detailed information of the related functions.
P06.01
Y1 output
0: Invalid
1: In operation
2: Forward rotation operation
3: Reverse rotation operation
4: Jogging operation
5: The VFD fault
6: Frequency degree test FDT1
7: Frequency degree test FDT2
8: Frequency arrival
9: Zero speed running
10: Upper limit frequency arrival
11: Lower limit frequency arrival
12: Ready for operation
13: In pre-exciting
14: Overload pre-alarm
15: Underload pre-alarm
16: Completion of simple PLC stage
17: Completion of simple PLC cycle
18: Reach set counting value
19: Reach specified counting value
20: External fault is valid
21: Reserved
22: Reach running time
23: Modbus communication virtual terminals output
24: PROFIBUS/CANopen communication virtual   terminals output
25: Ethernet communication virtual   terminals output
26: DC bus voltage established
27: Reserved 28: Pulse superposing 29: Reserved
30: Positioning finished
31: Zero returning
32: Spindle scaling
33: Speed limiting
34: Low bus voltage
35: Undervoltage stopping output
36: Speed/position switching finished
37–40: Reserved
P06.02
HDO output
P06.03
Relay RO1 output
P06.04
Relay RO2 output
5
P06.05
Polarity of output terminals
The function code is used to set the pole of the   output terminal.
When the current bit is set to 0, input terminal   is positive.
When the current bit is set to 1, input terminal   is negative.
Setting range: 0x0–0xF
0x0
P06.06
Y1 switch-on delay
The function code defines the corresponding delay   time of the electrical level change during the programmable terminal   switching on and off.
The setting range : 0.000–50.000s
Note: P06.08   and P06.08 are valid only when P06.00=1.
0.000 s
P06.07
Y1 switch-off delay
0.000 s
P06.08
HDO switch-on delay
0.000 s
P06.09
HDO switch-off delay
0.000 s
P06.10
RO1 switch-on delay
0.000 s
P06.11
RO1 switch-off delay
0.000 s
P06.12
RO2 switch-on delay
0.000 s
P06.13
RO2 switch-off delay
0.000 s
P06.14
AO1 output
0: Running frequency
1: Set frequency
2: Ramps reference frequency
3: Running speed
4: Output current (relative to 2 times the   rated current of the VFD)
5: Output current (relative   to 2 times the rated current of the motor)
6: Output voltage (relative to 1.5 times   the rated voltage of the VFD)
7: Output power (relative to 2 times the rated power of the motor)
8: Set torque value (relative to 2 times   the rated torque of the motor)
9: Output torque (relative to 2 times the   rated torque of the motor)
10:   Analog AI1 input value
11:   Analog AI2 input value
12:   Analog AI3 input value
13: Input   value of high-speed pulse HDIA
14: Set   value 1 of Modbus communication
15: Set   value 2 of Modbus communication
16: Set   value 1 of PROFIBUS\CANopen communication
17: Set   value 2 of PROFIBUS\CANopen communication
18: Set   value 1 of Ethernet communication
19: Set value 2 of Ethernet communication
20–21: Reserved
22: Torque current (bipolar, 100%   corresponds to 10 V)
23: Excitation current (100% corresponds to   10 V)
24: Setting frequency (bipolar)
25: Ramp reference frequency (bipolar)
26: Operation speed (bipolar)
27: Reserved
P06.15
AO2 output
P06.16
HDO high-speed pulse output
P06.17
Lower output limit of AO1
The above function codes define the relative   relationship between the output value and analog output. When the output value   exceeds the range of set maximum or minimum output, it will count according   to the low-limit or upper-limit output.
When the analog output is current output, 1mA   equals to 0.5 V.
In different cases, the corresponding analog   output of 100% of the output value is different. See each application for   detailed information. Please refer to section 7.10 "Analog   output" for more details.
Setting range of P06.17: -300.0%–P06.19
Setting range of P06.18: 0.00 V–10.00 V
Setting range of P06.19: P06.17–300.0%
Setting range of P06.20: 0.00 V–10.00 V
Setting range of P06.21: 0.000s–10.000s
Setting range of P06.22: -300.0%–P06.24
Setting range of P06.23: 0.00 V–10.00 V
Setting range of P06.24: P06.22–300.0%
Setting range of P06.25: 0.00 V–10.00 V
Setting range of P06.26: 0.000s–10.000s
Setting range of P06.27: -300.0%–P06.29
Setting range of P06.28: 0.00–50.00 kHz
Setting range of P06.29: P06.27–300.0%
Setting range of P06.30: 0.00–50.00 kHz
Setting range of P06.31: 0.000s–10.000s
0.0%
P06.18
Corresponding AO1 output of lower limit
0.00 V
P06.19
Upper output limit of AO1
100.0%
P06.20
Corresponding AO1 output of upper limit
10.00 V
P06.21
AO1 output filter time
0.000 s
P06.22
Lower output limit of AO2
0.0%
P06.23
Corresponding AO2 output of lower limit
0.00 V
P06.24
Upper output limit of AO2
100.0%
P06.25
Corresponding AO2 output of upper limit
10.00 V
P06.26
AO2 output filter time
0.000 s
P06.27
Lower output limit of HDO
0.00%
P06.28
Corresponding HDO output of lower limit
0.0 kHz
P06.29
Upper output limit of HDO
100.0%
P06.30
Corresponding HDO output of upper limit
50.00 kHz
P06.31
HDO output filter time
0.000 s
