Function code
Default    value
Modify
P12.00
Motor type 2
0: AM
1: SM
Note: Switch the current motor by the switching channel of P08.31.
P12.01
Rated power of AM 2
0.1–3000.0 kW
Set the parameter   of the controlled AM.
In order to   ensure the controlling performance, set the P12.01–P12.05 according to the name plate of the AM.
Goodrive35 series   VFDs provide the function of parameter autotuning. Correct parameter   autotuning comes from the correct setting of the motor name plate.
In order to   ensure the controlling performance, please configure the motor according to   the standard principles, if the gap between the motor and the standard one is   huge, the features of the VFD will decrease.
Note: Reset the rated power of the motor (P12.01), and initialize the motor   parameter of P12.02–P12.05.
Depend on model
P12.02
Rated frequency of AM 2
0.01 Hz–P00.03 (max. output frequency)
50.00 Hz
P12.03
Rated speed of AM 2
1–36000 rpm
Depend on model
P12.04
Rated voltage of AM 2
0–1200 V
Depend on model
P12.05
Rated current of AM 2
0.8–6000.0 A
Depend on model
P12.06
Stator resistor of AM 2
0.001–65.535 Ω
After finish the   motor parameter autotuning, the set value of P12.06–P12.10 will renew   automatically. These parameters are basic parameters controlled by vectors   which directly impact the features.
Note: Users cannot modify the parameters freely.
Depend on model
P12.07
Rotor resistor of AM 2
0.001–65.535 Ω
Depend on model
P12.08
Leakage inductance of AM 2
0.1–6553.5 mH
Depend on model
P12.09
Mutual inductance of AM 2
0.1–6553.5 mH
Depend on model
P12.10
Non-load current of AM 2
0.1–6553.5 A
Depend on model
P12.11
Magnetic saturation coefficient 1 for iron   core of AM2
0.0–100.0%
85.0%
P12.12
Magnetic saturation coefficient 2 for iron   core of AM2
0.0–100.0%
75.0%
P12.13
Magnetic saturation coefficient 3 for iron   core of AM2
0.0–100.0%
68.0%
P12.14
Magnetic saturation coefficient 4 for iron   core of AM2
0.0–100.0%
40.0%
P12.15
Rated power of SM 2
0.1–3000.0 kW
In order to   ensure the controlling performance, set the P12.15–P12.19 according to the name plate of the AM.
Note: Reset the rated power of the motor (P12.15), and initialize the motor   parameter of P12.16– P12.19.
Depend on model
P12.16
Rated frequency of SM 2
50.00 Hz
P12.17
Number of poles pairs for SM 2
1–128
P12.18
Rated voltage of SM 2
0–1200 V
Depend on model
P12.19
Rated current of SM 2
0.8–6000.0   A
Depend on model
Depend on model
P12.20
Stator resistor of SM 2
0.001–65.535   Ω
After finish the   motor parameter autotuning, the set value of P12.20–P12.22 will renew   automatically. These parameters are basic parameters controlled by vectors   which directly impact the features.
When P00.15=1,   the set value of P12.23 can be updated through autotuning automatically, and   there is no need to change the value of P12.23; when P00.15=2, the set value   of P12.23 cannot be updated through autotuning, please account and update the   value of P12.23.
Depend on model
P12.21
Direct axis inductance   of SM 2
0.01–655.35 mH
Depend on model
P12.22
Quadrature axis   inductance of SM 2
0.01–655.35 mH
P12.23
Back EMF constant of SM 2
When P00.15=2,   the set value of P12.23 cannot be updated by autotuning, please count according   to the following method.
The counter-electromotive force constant   can be counted according to the parameters on the name plate of the motor.   There are three ways to count:
1. If the name plate designate the   counter-electromotive force constant Ke, then:
E= (Ke*nN*2π)/ 60
2. If the name plate designate the   counter-electromotive force constant E’ (V/1000r/min), then:
E=E’*nN/1000
3. If the name plate does not designate the   above parameters, then:
E=P/√3*I
In the above formulas: nN is the   rated rotation speed, P is the rated power and I is the rated current.
Setting range: 0–10000
320
P12.24
Initial pole position of SM 2 (reserved)
0–FFFFH (reserved)
0x0000
P12.25
Identification current of SM 2 (reserved)
0%–50% (the rated current of the motor) (reserved)
10%
P12.26
Motor 2 overload protection
0: No protection
1: Common motor (with   low speed compensation)
2: Variable-frequency   motor (without low speed compensation)
P12.27
Motor 2 overload protection coefficient
Motor overload multiple M = Iout/(In × K)
In is the rated current of the motor, Iout   is the output current of the VFD and K is the motor overload protection   coefficient.
The smaller K is, the greater M is, and the   more likely protection is implemented.
When M=116%, protection is performed after   motor overload lasts for 1 hour; when M=150%, protection is performed after   motor overload lasts for 12 minutes; when M=180%, protection is performed   after motor overload lasts for 5 minutes; when M=200%, protection is   performed after motor overload lasts for 60 seconds; and when M≥ 400%, protection is performed   immediately.
Setting range: 20.0%–120.0%
100.0%
P12.28
Reserved
P12.29
Parameter display of motor 2
0: Display   according to the motor type: only the parameters relative to the current motor   type are displayed for the convenient for the customers in this mode.
1: All parameters   are displayed: all parameters are displayed in this mode.
