Function code
Default    value
Modify
P13.00
Reduction coefficient of source current
0.0–100.0%   (rated current of the motor)
80.0%
P13.01
Original pole test   mode
0: No test
1: High-frequency   superposition (reserved)
2: Pulse   superposition (reserved)
P13.02
Source current 1
Source   current is the positioning current of the magnetic pole position. Source   current 1 is valid under the frequency point of current shifting. Increasing   the value can raise the starting torque.
Setting   range: 0.0%–100.0% (rated current of the motor)
20.0%
P13.03
Source current 2
Source   current is directional current of the magnetic pole position. Source current   2 is valid under the frequency point of current shifting. There is no need to   modify the value generally.
Setting   range: 0.0%–100.0% (rated current of motor)
10.0%
P13.04
Shift frequency of   source current
0.0%–80.0%   (max frequency)
20.0%
P13.05
Reserved
P13.06
High-frequency superposing voltage
0.0–300.0% (rated   voltage of the motor)
100.0%
P13.07
Control parameter 0
0.0–400.0%
0.0%
P13.08
Control parameter 1
0x0000–0xFFFF
0x0000
P13.09
Control parameter 2
0.00–655.35
2.00
P13.10
Initial angle compensation of synchronous   machine
0.0–359.9
0.0
P13.11
Maladjustment   detection time
Adjust the response   of anti-maladjustment. Bigger load inertia may increase the value, but the   response will be slower.
Setting   range: 0.0–10.0 s
0.5 s
P13.12
High-frequency   compensation coefficient of synchronous machine
When the motor speed   is faster than the rated speed, the parameter is valid, if vibration occurs   to the motor, please adjust the parameter.
Setting   range: 0.0–100.0%
0.0%
P13.13
Brake current of   short-circuit
When P01.00=0 during   the starting of the VFD, set P13.14 to a non-zero value to enter the short   circuit brake.
When the running   frequency is lower than P01.09 during the stopping of the VFD, set 13.15 to a   non-zero value to enter into stopping short circuited brake and then carry   out the DC brake at the time set by P01.12 (refer to the instruction of P01.09–P01.12)   .
Setting range of P13.13:   0.0–150.0% (the VFD)
Setting range of P13.14:   0.0–50.0s
Setting range of 13.15:   0.0–50.0s
0.0%
P13.14
Brake retention time   before  starting
0.0 s
P13.15
The brake retention   time when stopping
0.0 s
