Function code
Default    value
Modify
P17.00
Setting frequency
Display   current set frequency of the VFD
Range: 0.00   Hz–P00.03
0.00 Hz
P17.01
Output frequency
Display   current output frequency of the VFD
0.00 Hz
P17.02
Ramp reference   frequency
Display   current ramp reference frequency of the VFD
0.00 Hz
P17.03
Output voltage
Display   current output voltage of the VFD
Range: 0–1200   V
0 V
P17.04
Output current
Display present   output current of the VFD
Range: 0.0–5000.0   A
0.0 A
P17.05
Motor speed
Display   the rotation speed of the motor.
Range: 0–65535 RPM
0 RPM
P17.06
Torque current
Display present   torque current of the VFD
Range: -3000.0–3000.0 A
0.0 A
P17.07
Exciting current
Display present   exciting current of the VFD
0.0 A
P17.08
Motor power
Display present   power of the motor.
Setting range: -300.0%–300.0% (rated power of the motor)
0.0%
P17.09
Output torque
Display   the current output torque of the VFD; 100% relative to rated torque of the   motor. During forward running, the positive value is the motoring state while   the negative value is generating state. During reverse running, the positive   value is the generating state while the negative value is the motoring state.
Range: -250.0–250.0%
0.0%
P17.10
Evaluated motor   frequency
Evaluate   the motor rotor frequency on closed-loop vector
Range: 0.00–P00.03
0.00 Hz
P17.11
DC bus voltage
Display   current DC bus voltage of the VFD.
Range: 0.0–2000.0 V
0.0 V
P17.12
Digital input   terminals state
Display present   digital input terminals state of the VFD.
Range: 0000–01FF
P17.13
Digital output   terminals state
Display present   digital output terminals state of the VFD.
Range: 0000–000F
P17.14
Digital adjustment
Display   the adjustment via the VFD keypad
Range : 0.00 Hz–P00.03
0.00 Hz
P17.15
Torque reference
Display   the torque given, the percentage to the current rated torque of the motor.
Setting range: -300.0%–300.0% (rated current of the motor)
0.0%
P17.16
AI1   adjustment voltage
Display A1 adjustment voltage.
0.00–10.00 V
0.00 V
P17.17
AI2   adjustment voltage
Display A2 adjustment voltage.
0.00–10.00 V
0.00 V
P17.18
AI3 adjustment voltage
Display A3   adjustment voltage.
0.00–10.00 V
0.00 V
P17.19
AI1 input voltage
Display   analog AI1 input signal
Range: 0.00–10.00 V
0.00 V
P17.20
AI2 input voltage
Display   analog AI2 input signal
Range: 0.00–10.00 V
0.00 V
P17.21
AI3 input voltage
Display   analog AI3 input signal
Range: -10.00–10.00 V
0.00 V
P17.22
HDI input frequency
Display   HDI input frequency
Range: 0.00–50.00 kHz
0.00 kHz
P17.23
PID reference
Display   PID reference value.
Range: -100.0–100.0%
0.0%
P17.24
PID feedback
Display   PID feedback value
0.0%
P17.25
Power factor of the   motor
Display   the current power factor of the motor.
Range: -1.00–1.00
0.00
P17.26
Current running time
Display   the current running time of the VFD.
Range: 0–65535 min
0 min
P17.27
Simple PLC and the   current step of the multi-step speed
Display   simple PLC and the current stage of the multi-step speed
Range: 0–15
P17.28
ASR controller   output
This   parameter is used to display the output value of the automatic speed   regulator (ASR). The value is relative to the rated torque of the motor.
Range:   -300.0%–+300.0% (the rated torque of the motor)
0.0%
P17.29
Initial   identification angle of synchronous machine
Display   initial identification angle of synchronous machine
Range: 0.0–359.9
0.0
P17.30
Phase compensation   of SM
Display   SM phase compensation
Range: -180.0–180.0
0.0
P17.31
Reserved
P17.32
Reserved
P17.33
Exciting current   reference
Display the exciting current reference in the vector control mode
0.0 A
P17.34
Torque current   reference
Display the torque current reference in the vector control mode
0.0 A
P17.35
AC current
Display the value of inlet current in AC   side
Range: 0.0–5000.0 A
0.0 A
P17.36
Output   torque
Display the output torque value. During forward   running, the positive value is the motoring state while the negative value is   generating state. During reverse running, the positive value is the   generating state while the negative value is the motoring state.
Range : -3000.0Nm–3000.0 Nm
0.0 Nm
P17.37
PID deviation
-100.0%–100.0%
0.0%
P17.38
PID output
-200.00%–200.00%
0.00%
P17.39
Wrong download of   parameters
0.00–29.00
0.00
