Function code
Default    value
Modify
P18.00
Actual frequency detected by the encoder
P18.00 is   the actual frequency of the encoder. If the motor rotates forward, the value   is positive; if the motor rotates reverse, the value is negative.
Range: -3276.8–3276.7   Hz
0.0 Hz
P18.01
Position counting of the encoder
Position   counting of the encoder, 4 times of the frequency
Range: 0–65535
P18.02
Pulse Z counting of the encoder
Range: 0–65535
P18.03
MSB of the position reference
The value   will be cleared if stopping.
Range: 0–30000
P18.04
LSB of the position reference
Range: 0–65535
P18.05
MSB of the position feedback
Range: 0–30000
P18.06
LSB of the position feedback
Range: 0–65535
P18.07
Position deviation
The   deviation between reference position and actual operation position.
Range: -32768–32767
P18.08
Position reference
The reference position of pulse Z when spindle   stops.
Range: 0–65535
P18.09
Current position of the spindle
Current position setting when spindle stops.
Range: 0–359.99
0.00
P18.10
Current position at spindle orientation
Current position of the spindle at the oriented   spindle stop.
Range: 0–65535
P18.11
Reverse of pulse Z
Display   of pulse Z direction. When the spindle stops, the stopping position of   forward and reverse rotation may have a deviation of a few pulses. After   adjusting the direction of pulse Z or the AB phase of encoder, the stopping   position will be same.
0: Forward
1: Reverse
P18.12
Pulse Z angle
Reserved
Range: 0–359.99
0.00
P18.13
Fault times of pulse Z
Reserved
Range: 0–65535
P18.14
MSB of encoder pulse counting
After   power on, the value will be counted continuously.
Range: 0–65535
P18.15
LSB of encoder pulse counting
Range: 0–65535
P18.17
Pulse command frequency
Pulse command (terminals A2 and B2) is converted   into setting frequency and keeps valid in pulse position mode and pulse speed   mode
Range: 0.0–400.0   Hz
0.0 Hz
P18.18
Pulse command forward feedback
Range: 0.0–400.0 Hz
0.0 Hz
P18.19
Position regulator output
The position regulator output frequency in   position control.
Range: 0.00–400.00 Hz
0.00 Hz
P18.20
Rotary transformer counting
Rotary transformer counting, 0–1024.
Range: 0–65535
P18.21
Rotary transformer angle
The magnetic position angle from the rotary   transformer.
Range: 0.00–359.99
0.00
P18.22
Pole angle
Current   magnetic position.
Range: 0.00–359.99
0.00
P18.23
State control word 3
Range: 0–65535
P18.24
MSB of pulse reference counting
Range: 0–65535
P18.25
LSB of pulse reference counting
Range: 0–65535
P18.26
Inertia compensation torque
Range: -100.0%–100.0%
0.0%
P18.27
Friction compensation torque
The torque value of friction   compensation.
0.0%
P18.28
Spindle drive ratio
The drive   ratio of encoder installation shaft to spindle when the spindle stops.
Range: 0.000–65.535
0.000
P18.30
Reserved
