Function code
Default    value
Modify
P20.00
Encoder type
0: Incremental   encoder
1: ABZUVW encoder
2: Resolver encoder
3: Sin/cos   encoder without CD signal
4: Sin/cos   encoder with CD signal
P20.01
Pulse number
Pulse   number when the encoder rotates a circle.
Range: 0–60000
1024
P20.02
Encoder direction
Setting range: 0x000–0x111
Ones: Encoder AB   direction
0: Forward
1: Reverse
When encoder offline   fault (ENC10) or encoder reverse fault (ENC1D) is reported, adjust this   function code to change the AB pulse direction, removing the need of   re-adjusting the wiring of AB pulse.
Tens: Pulse   Z direction
0: Forward
1;   Reverse
No   setting required
Hundreds:   Direction of magnetic pole signal
0: Forward
1: Reverse
Perform   rotary autotuning on magnetic pole position (P20.11=1 or 3), if autotuning is   succeeded, the magnetic pole signal direction will be set automatically.
0x000
P20.03
Encoder disconnection fault reporting   threshold time
Detection time of encoder offline fault.
Range: 0.0–100.0   s
1.0 s
P20.04
Encoder reverse running fault reporting   threshold time
Detection time of encoder reverse fault.
Range: 0.0–100.0   s
0.8 s
P20.05
Number of encoder detection filtering times
Setting   range: 0x00–0x99
Ones   place: Number of low-speed filtering times; corresponding to 2^(0–9)×125 μs
Tens   place: Number of high-speed filtering times; corresponding to 2^(0–9)×125 μs
0x33
P20.06
Rotating speed ratio of the motor to   encoder
When the   encoder is not mounted on the shaft of the motor and the drive ratio is not   1, you need to set this parameter.
Setting   range: 0.001–65.535
1.000
P20.07
Control parameters of SM
Setting   range: 0x0000–0xFFFF
Generally,   you do not need to modify this parameter.
Bit0: Enabling   pulse Z calibration
Bit1: Enabling   encoder angle calibration
Bit2:   Enabling SVC speed measurement
Bit3: Setting   resolver speed measurement mode
Bit4: Setting   pulse Z capture mode
Bit12: Deleting   pulse Z arrival signal when the machine is stopped
0x0003
P20.08
Enabling pulse Z disconnection detection
ENC1Z indicates pulse Z disconnection fault. When   the spindle orientation function is used or an incremental encoder is used   for the synchronous machine, you can enable pulse Z detection to prevent   inaccurate orientation or synchronous machine control failure caused due to   pulse Z loss.
0: Disabled
1: Enabled
P20.09
Initial angle of pulse Z
Electrical   degree between pulse Z of the encoder and the magnetic pole position of the   motor.
Setting   range: 0.00–359.99
0.00
P20.10
Pole initial angle
Electrical   degree between the position of the encoder and the magnetic pole position of   the motor.
0.00
P20.11
Autotuning of magnetic pole initial angle
Setting   range: 0–3
0: No   operation
1: Rotary   autotuning (no load)
2: Static   autotuning (fit for resolver and sin/cos encoder)
3: Rotary   autotuning (loaded)
After   setting the value to 1 or 2, the keypad will display "-RUN-", then   press "RUN" to begin the autotuning until the keypad display "-END-".   The identified initial angle is saved in P20.09 and P20.10.
The pole   initial angle obtained from rotary autotuning 1 is more accurate. Generally   it is necessary to de-couple the motor or lighten the motor load for rotary   autotuning.
P20.12
Encoder signal filter width
Range: 0.0–20.0us
0.5 us
P20.13
Speed optimization enabling
0: Disabled
1: Enabled
0–1
