Check the machine before beginning to use the VFD:
1. Check the load   type to verify that there is no overload of the VFD during work and check   that whether the drive needs to modify the power degree.
2. Check that the actual current of the motor is   less than the rated current of the VFD.
3. Check that the control accuracy of the load is   the same of the VFD.
4. Check that the incoming supply voltage is   correspondent to the rated voltage of the VFD.
5. Check that the communication needs option card   or not.
