Check as followings before the actual installation and usage:
1. Check that the ambient temperature of the VFD   is below 40°C. If temperature is above 40°C, derate 1% for every additional 1°C.   Additionally, the VFD cannot be used if the ambient temperature is above 50°C.
Note: for the cabinet VFD, the ambient temperature means   the air temperature inside the cabinet.
2. Check that the ambient temperature of the VFD   in actual usage is above -10°C. If not, add heating facilities.
3. Check that the altitude of the actual usage   site is below 1000m.   If exceeds, derate1% for every additional 100m.
4. Check that the humidity of the actual usage   site is below 90% and condensation is not allowed. If not, add additional   protection VFDs.
5. Check that the actual usage site is away from   direct sunlight and foreign objects cannot enter the VFD. If not, add   additional protective measures.
6. Check that there is no conductive dust or   flammable gas in the actual usage site. If not, add additional protection to VFDs.
