Function
Specification
Power input
Input voltage (V)
AC 3PH 380V   (-15%)–440V (+10%)
Rated   voltage: 380V;
AC 3PH   380V (-10%)–550V (+10%)
Rated   voltage: 500V;
AC 3PH 520V   (-15%)–690V (+10%)
Rated   voltage: 660V
Input
current (A)
Refer to the rated value
Input frequency (Hz)
50Hz or 60Hz
Allowed   range: 47–63Hz
Power output
Output voltage (V)
0–input voltage
Output current (A)
Output power (kW)
Output frequency (Hz)
0–400Hz
Technical control feature
Control mode
SVPWM, sensorless   vector control
Motor
 type
Asynchronous   motor and permanent magnet synchronous motor
Adjust-able-
speed
ratio
Asynchronous   motor 1:200 (SVC) synchronous motor 1:20 (SVC)
Speed control accuracy
±0.2% (sensorless   vector control)
Speed fluctuation
± 0.3%(sensorless   vector control)
Torque response
<20ms   (sensorless vector control)
Torque control accuracy
10%(sensorless   vector control)
Starting torque
Asynchronous   motor: 0.25Hz/150% (SVC)
Synchronous   motor: 2.5 Hz/150% (SVC)
Overload capability
150% of rated   current: 1 minute
180% of rated   current: 10 seconds
200% of rated   current: 1 second
Running control feature
Frequency setting method
Digital setting, analog setting, pulse frequency   setting, multi-step speed running setting, simple PLC setting, PID setting, Modbus   communication setting, PROFIBUS communication setting.
Switch between the combination and single setting channel.
Auto-adjust-
ment
of the voltage
Keep constant voltage automatically when the grid   voltage transients
Fault protection
Provide more than 30 fault protection functions:   overcurrent, overvoltage, undervoltage, overheating, phase loss and overload,   etc.
Restart
after rotating   speed tracking
Smooth starting of the rotating motor
Peripheral interface
Terminal analog input resolution
≤ 20mV
Terminal switch
input resolution
≤ 2ms
Analog input
2 (AI1, AI2) 0–10V/0–20mA and 1 (AI3) -10–10V
Analog output
2 (AO1, AO2)   0–10V /0–20mA
Digital input
8 common   inputs, the Max. frequency: 1kHz, internal impedance: 3.3kΩ;
1 high   speed input, the Max. frequency: 50kHz
Digital output
1 high   speed pulse output, the Max. frequency: 50kHz;
1 Y   terminal open collector output
Relay output
2   programmable relay outputs
RO1A NO, RO1B NC, RO1C common terminal
RO2A NO, RO2B NC, RO2C common terminal
Contactor   capability: 3A/AC250V,1A/DC30V
Others
Mountable method
Wall, flange   and floor mountable
Tempe-rature
of the running enviro-nment
-10–50°C,   derate above 40°C
Average non-fault time
2 years (25°C   ambient temperature)
Protective degree
IP20
Cooling
Air-cooling
Pollution degree
Degree 2
Braking
 unit
Built-in   for VFDs of 380V (≤30kW), optional for VFDs of 380V (≥37kW)
Built-in   for VFDs of 500V (≤18.5kW), optional for VFDs of 500V (≥22kW)
Optional   for VFDs of 660V
EMC
filter
The whole   series of 380V VFDs can meet the requirements of level C3 stipulated in   IEC61800-3.
External   filters that meet the requirements of level C2 stipulated in IEC61800-3 are   optional.
