The model code contains information about the VFD. You can find the model code on the name plate on the VFD or the simplified nameplate.
Figure 3-7 Product type
Field
No.
Detailed description
Detailed content
Abbreviation
①
Product abbreviation
GD300 is short for Goodrive300.
Rated power
②
Power range + Load type
5R5—5.5kW
G—Constant torque load
Voltage degree
③
Voltage degree
4: AC 3PH 380V (-15%)–440V (+10%)
Rated voltage: 380V;
5: AC 3PH 380V (-10%)–550V (+10%) Rated   voltage: 500V;
6: AC 3PH 520V (-15%)–690V (+10%)
Rated voltage: 660V
