3.6.1 AC 3PH 380V (-15%)–440V (+10%)
Model
Rated    output power (kW)
Rated    input current (A)
Rated    output current (A)
GD300-1R5G-4
1.5
5.0
3.7
GD300-2R2G-4
2.2
5.8
5
GD300-004G-4
4
13.5
9.5
GD300-5R5G-4
5.5
19.5
14
GD300-7R5G-4
7.5
25
18.5
GD300-011G-4
11
32
25
GD300-015G-4
15
40
32
GD300-018G-4
18.5
47
38
GD300-022G-4
22
56
45
GD300-030G-4
30
70
60
GD300-037G-4
37
80
75
GD300-045G-4
45
94
92
GD300-055G-4
55
128
115
GD300-075G-4
75
160
150
GD300-090G-4
90
190
180
GD300-110G-4
110
225
215
GD300-132G-4
132
265
260
GD300-160G-4
160
310
305
GD300-200G-4
200
385
380
GD300-220G-4
220
430
425
GD300-250G-4
250
485
480
GD300-280G-4
280
545
530
GD300-315G-4
315
610
600
GD300-350G-4
350
625
650
GD300-400G-4
400
715
720
GD300-500G-4
500
890
860
1. The input current of VFDs 1.5–315kW is detected when the input voltage is 380V and there are no DC reactors and input/output reactors.
2. The input current of VFDs 350–500kW is detected when the input voltage is 380V and there are input reactors.
3. The rated output current is defined as the output current generated when the output voltage is 380V.
4. Within the allowed input voltage range, the output current cannot exceed the rated output current, and the output power cannot exceed the rated output power.
3.6.2 AC 3PH 380V (-10%)–550V (+10%)
Model
GD300-004G-5
4
11
8
GD300-5R5G-5
5.5
15
10
GD300-7R5G-5
7.5
19
14
GD300-011G-5
11
26
20
GD300-015G-5
15
32
26
GD300-018G-5
18.5
40
34
GD300-022G-5
22
48
42
GD300-030G-5
30
60
53
GD300-037G-5
37
66
63
GD300-045G-5
45
78
75
GD300-055G-5
55
95
92
GD300-075G-5
75
126
120
1. The input current of VFDs 1.5–75kW is detected when the input voltage is 500V and there are no DC reactors and input/output reactors.
2. The rated output current is defined as the output current generated when the output voltage is 500V.
3. Within the allowed input voltage range, the output current cannot exceed the rated output current, and the output power cannot exceed the rated output power.
3.6.3 AC 3PH 520V (-15%)–690V (+10%)
Model
GD300-022G-6
22
35
27
GD300-030G-6
30
40
35
GD300-037G-6
37
47
45
GD300-045G-6
45
52
52
GD300-055G-6
55
65
62
GD300-075G-6
75
85
86
GD300-090G-6
90
95
98
GD300-110G-6
110
118
120
GD300-132G-6
132
145
150
GD300-160G-6
160
165
175
GD300-185G-6
185
190
200
GD300-200G-6
200
210
220
GD300-220G-6
220
230
240
GD300-250G-6
250
255
270
GD300-280G-6
280
286
300
GD300-315G-6
315
334
350
GD300-350G-6
350
360
380
GD300-400G-6
400
411
430
GD300-500G-6
500
518
540
GD300-560G-6
560
578
600
GD300-630G-6
630
655
680
1. The input current of VFDs 22–350kW is detected when the input voltage is 660V and there are no DC reactors and input/output reactors.
2. The input current of VFDs 400–630kW is detected when the input voltage is 660V and there are input reactors.
3. The rated output current is defined as the output current generated when the output voltage is 660V.
