Figure 3-8 shows the layout of the VFD (taking the VFD of 380V 30kW as an example).
Figure 3-8 Product structure
No.
Description
Keypad port
Connect the keypad.
Upper cover
Protect the internal parts and components.
3
Keypad
See Keypad   Operation Procedure for   detailed information.
4
Cooling fan
See Maintenance   and Hardware Fault Diagnose for detailed information.
5
Wiring port
Connect to the control board and the drive board.
6
Name plate
See Product   Overview for detailed information.
7
Side cover
Optional. The side cover will increase the protective degree of the VFD,   however, the internal temperature of the VFD will also increase, so it is   necessary to derate the VFD at the same time.
8
Control terminals
See Electric   Installationfor detailed   information.
9
Main circuit   terminals
10
Main circuit   cable port
Fix the main circuit cable.
11
POWER light
Power indicator.
12
Simple name plate
See Model   codes for detailed information.
13
Lower cover
