Check before powering on
Please check according to the installation list in chapter two.
First powering operation
Check to ensure there is no mistake in wiring and power supply, switch on the air switch of the AC power supply on the input side of the VFD to power on the VFD. 8.8.8.8.8. will be displayed on the keypad, and the contactor closes normally. When the character on the nixie tubs changes to the set frequency, the VFD has finished the initialization and it is in the stand-by state.
Below diagram shows the first operation: (take motor 1 as the example)
Note:If fault occurs, please do as the "Fault Tracking". Esitimate the fault reason and settle the issue.
Besides P00.01 and P00.02, terminal command setting can also used to set the running command channel.
Current running command channel
P00.01
Multi-function
terminal
36
Switch
 to keypad
Multi-function terminal 37
Switch to to terminal
Multi-
function
terminal
38
Switch to
commun-
ication
Keypad
Terminal
Communication
Terminal
Keypad
Communication
Communication
Keypad
Terminal
Note: "/" means the multi-function terminal is invalid on the current given channel.
Related parameters:
Function code
Detailed
instruction
of parameters
Default value
P00.00
Speed control mode
0: Sensorless vector control mode 0 (apply to AM and SM)
1: Sensorless vector control mode 1 (applying to AM)
2: SVPWM   control
P00.01
Running command channel
0: Keypad
1:Terminal   ("LOCAL/REMOT"   flickering)
2:Communication   ("LOCAL/REMOT"   on)
P00.02
Communication running commands
0: Modbus communication channel
1: PROFIBUS\CANopen   communication channel
2: Ethernet communication channel
3: Reserved
P00.18
Function
restore parameter
0: No operation
1: Restore the default value
2: Cancel   the fault record
P00.15
Motor parameter autotuning
0: No operation
1: Rotating autotuning
2: Static autotuning 1 (autotune totally)
3: Static   autotuning 2 (autotune part parameters)
P02.00
Motor type 1
0: Asynchronous motor
1: Synchronous   motor
P02.01
Rated power of asynchronous motor 1
0.1–3000.0kW
Depend on model
P02.02
Rated frequency of asynchronous motor 1
0.01Hz–P00.03   (Max. output frequency)
50.00Hz
P02.03
Rated speed of asynchronous motor 1
1–36000rpm
Depend on model
P02.04
Rated voltage of asynchronous motor 1
0–1200V
Depend on model
P02.05
Rated current of asynchronous motor 1
0.8–6000.0A
Depend on model
P02.15
Rated power of synchronous motor 1
0.1–3000.0kW
Depend on model
P02.16
Rated frequency of synchronous motor 1
0.01Hz–P00.03   (Max. frequency)
50.00Hz
P02.17
Number of poles pairs for synchronous motor   1
1–50
P02.18
Rated voltage of synchronous motor 1
0–1200V
Depend on model
P02.19
Rated current of synchronous motor 1
0.8–6000.0A
Depend on model
P05.01–P05.09
Multi-function   digital input terminals
(S1–S8,HDI) function selection
36: Shift   the command to keypad
37: Shift   the command to terminals
38: Shift   the command to communication
P07.01
Parameter copy
The function code determines the manner of   parameters copy.
0: No operation
1: Upload the local function parameter to   the keypad
2: Download the keypad function parameter   to local address (including the motor parameters)
3: Download the keypad function parameter   to local address (excluding the motor parameter of P02 and P12 group)
4: Download the keypad function parameters   to local address (only for the motor parameter of P02 and P12 group)
P07.02
QUICK/JOG function selection
0: No function
1: Jogging
2: Shift the display state by the shifting   key
3: Shift between forward rotations and   reverse rotations
4: Clear UP/DOWN settings
5: Coast to stop
6: Shift the given manner of running   commands
7: Quick commission mode (committee   according to the non-factory parameter)
