Because asynchronous motors have the characteristics of high stage, nonlinear, strong coupling and various variables, the actual control of the asynchronous motor is very difficult. Vector control is mainly used to settle this problem with the theme of that divide the stator current vector into exciting current (the current heft generating internal magnetic field of the motor) and torque current (the current heft generating torque) by controlling and measuring the stator current vector according to the principles of beamed magnetic field to control the range and phase of these two hefts. This method can realize the decoupling of exciting current and torque current to adjust the high performance of asynchronous motors.
Goodrive300 series VFDs are embedded speedless sensor vector control calculation for driving both asynchronous motors and synchronous motors. Because the core calculation of vector control is based on exact motor parameter models, the accuracy of motor parameter will impact on the performance of vector control. It is recommended to input the motor parameters and carry out autotune before vector running.
Because the vector control calculation is vary complicated, high technical theory is needed for the user during internal autotune. It is recommended to use the specific function parameters in vector control with cautions.
Function code
Default value
P00.00
Speed control mode
0: Sensorless vector control mode 0 (apply to AM and   SM)
1: Sensorless vector control mode 1 (applying to AM)
2: SVPWM   control
P00.15
Motor parameter   autotuning
0: No operation
1: Rotating   autotuning
2: Static autotuning   1 (autotune all motor parameters)
3: Static   autotuning 2 (autotune some of the motor parameters)
P02.00
Type of motor 1
0: Asynchronous   motor
1: Synchronous   motor
P03.00
Speed loop   proportional gain1
0–200.0
20.0
P03.01
Speed loop integral   time1
0.000–10.000s
0.200s
P03.02
Low switching
frequency
0.00Hz–P03.05
5.00Hz
P03.03
Speed loop   proportional gain 2
0–200.0
20.0
P03.04
Speed loop integral   time 2
0.000–10.000s
0.200s
P03.05
High switching
frequency
P03.02–P00.03   (Max. frequency)
10.00Hz
P03.06
Speed loop output   filter
0–8 (corresponding   to 0–28/10ms)
P03.07
Compensation   coefficient of electromotion slip in vector control
50%–200%
100%
P03.08
Compensation   coefficient of braking slip in vector control
50%–200%
100%
P03.09
Current loop proportional   coefficient P
0–65535
1000
P03.10
Current loop   integral coefficient I
0–65535
1000
P03.11
Torque setting   method
This parameter is   used to enable the torque control mode, and set the torque.
0: Torque control is   invalid
1: Keypad setting   torque (P03.12)
2: Analog AI1   setting torque
3: Analog AI2   setting torque
4: Analog AI3   setting torque
5: Pulse frequency   HDI setting torque
6: Multi-step torque   setting
7: Modbus   communication setting torque
8: PROFIBUS/CANopen   communication setting torque
9: Ethernet   communication setting torque
10:   Reserved
Note:   For setting modes of 2–10, 100% corresponds to three times of the rated current   of the motor.
P03.12
-300.0%–300.0%
(rated   current of the motor)
50.0%
P03.13
Torque reference   filter time
0.000–10.000s
0.010s
P03.14
Upper frequency of   forward rotation in torque control
0: Keypad (P03.16 sets P03.14, P03.17 sets   P03.15)
1: AI1
2: AI2
3: AI3
4: Pulse frequency HDI
5: Multi-step
6: Modbus communication
7: PROFIBUS/CANopen communication
8: Ethernet communication
9:   Reserved
Note: For setting modes   of 1–9, 100% corresponds to the maximum frequency.
P03.15
Upper frequency of   reverse rotation in torque control
P03.16
Keypad setting for   upper frequency of forward rotation in torque control
Setting   range: 0.00Hz–P00.03
(Max.   output frequency)
50.00Hz
P03.17
Keypad setting for   upper frequency of reverse rotation in torque control
50.00Hz
P03.18
Upper   electromotion torque limit setting source
0: Keypad (P03.20 sets P03.18, P03.21 sets   P03.19)
1: AI1
2: AI2
3: AI3
4: HDI
5: Modbus communication
6: PROFIBUS/CANopen communication
7: Ethernet communication
8:   Reserved
  Note: For setting modes of 1–8,   100% corresponds tothree times of the motor current.
P03.19
Upper braking   torque limit setting source
P03.20
Keypad setting of   electromotion torque
0.0–300.0%   (rated current of the motor)
180.0%
P03.21
Keypad setting of   braking  torque
180.0%
P03.22
Weakening   coefficient in constant power zone
0.1–2.0
0.3
P03.23
Lowest weakening   point in constant power zone
10%–100%
20%
P03.24
Max. voltage limit
0.0–120.0%
100.0%
P03.25
Pre-exciting time
0.000–10.000s
0.300s
P17.32
Magnetic flux   linkage
0.0–200.0%
