Goodrive300 series VFDs support two kinds of control mode: torque control and rotation speed control. The core of rotation speed is that the whole control focuses on the stable speed and ensures the setting speed is the same as the actual running speed. The Max. Load sould be in the range of the torque limit. The core of torque control is that the whole control focues on the stable torque and ensures the setting torque is the same as the actual output torque. At the same time, the output frequency is among the upper limit or the lower limit.
Function code
Default value
P00.00
Speed control mode
0: Sensorless vector control mode 0 (applicable to AM   and SM)
1: Sensorless vector control mode 1 (applicable to AM)
2: SVPWM control   mode (applicable to AM and SM)
P03.11
Torque setting method
0: Torque control is   invalid
1: Keypad setting   torque (P03.12)
2: Analog AI1   setting torque
3: Analog AI2   setting torque
4: Analog AI3   setting torque
5: Pulse frequency HDI   setting torque
6: Multi-step torque   setting
7: Modbus   communication setting torque
8: PROFIBUS\CANopen   communication setting torque
9: Ethernet   communication setting torque
10: Reserved
P03.12
-300.0%–300.0%
(rated current of   the motor)
50.0%
P03.13
Torque reference filter time
0.000–10.000s
0.010s
P03.14
Upper frequency of forward rotation in   vector control
0: Keypad (P03.16 sets P03.14, P03.17 sets P03.15)
1: AI1
2: AI2
3: AI3
4: Pulse frequency HDI setting upper-limit   frequency
5: Multi-step setting upper-limit frequency
6: Modbus communication setting upper-limit   frequency
7: PROFIBUS/CANopen   communication setting upper-limit frequency
8: Ethernet communication setting upper-limit frequency
9: Reserved
P03.15
Upper frequency of reverse rotation in   vector control
P03.16
Keypad setting for upper frequency of   forward rotation in torque control
0.00Hz–P00.03 (Max. frequency)
50.00 Hz
P03.17
Keypad setting for upper frequency of   reverse rotation in torque control
0.00 Hz–P00.03 (Max. frequency)
50.00 Hz
P03.18
Upper   electromotion torque limit setting source
0: Keypad setting upper-limit frequency (P03.20   sets P03.18, P03.21 sets P03.19)
1: AI1
2: AI2
3: AI3
4: HDI
5: Modbus communication
6: PROFIBUS/CANopen   communication
7: Ethernet communication
8: Reserved
P03.19
Upper braking   torque limit setting source
P03.20
Keypad setting of upper electromotion torque   limit
0.0–300.0% (rated current of   the motor)
180.0%
P03.21
Keypad setting of upper braking torque   limit
180.0%
P17.09
Output torque
-250.0–250.0%
0.0%
P17.15
Torque reference
-300.0–300.0% (rated current of the motor)
0.0%
