•  Physical accident may occur if the motor starts up   suddenly during autotune. Please check the safety of surrounding environment   of the motor and the load before autotune.
•  The power is still applied even the motor stops   running during static autotune. Please do not touch the motor until the   autotune is completed, otherwise there would be electric shock.
•  Do not carry out the rotation autotune if the   motor is coupled with the load, please do not operate on the rotation   autotune. Otherwise misaction or damage may occur to the VFD or the mechanical   devices. When carry out autotune on the motor which is coupled with load, the   motor parameter won’t be counted correctly and misaction may occur. It is   proper to de-couple the motor from the load during autotune when necessary.
Goodrive300 series VFDs can drive both asynchronous motors and synchronous motors. And at the same time, they can support two sets of motor parameters which can shift between two motors through multi-function digital input terminal or communication.
The control performance of the VFD is based on the established accurate motor model. The user has to carry out the motor autotune before first running (take motor 1 as an example).
1. Set the motor parameters according to the name plate of the motor.
2. During the motor autotune, de-couple the motor form the load if rotation autotune is selected to make the motor is in a static and empty state, otherwise the result of autotune is incorrect. The asynchronous motors can autotune the parameters of P02.06–P02.10, while the synchronous motors can autotune the parameters of P02.20–P02.23.
3. During the motor autotune, do not to de-couple the motor form the load if static autotune is selected. Because only some parameters of the motor are involved, the control performance is not as better as the rotation autotune.  The asynchronous motors can autotune the parameters of P02.06–P02.10, while the synchronous motors can autotune the parameters of P02.20–P02.22. P02.23 (synchronous motor 1 counter-electromotive force constant) can be counted to attain.
4. Motor autotune only involves the current motor. Switch the motor through P08.31 to carry out the autotune on the other motor.
Related parameters
Function    code
Default    value
P00.01
Running command channel
0: Keypad
1: Terminal   ("LOCAL/REMOT"   flickering)
2: Communication   ("LOCAL/REMOT"   on)
P00.15
Motor parameter autotuning
0: No operation
1: Rotating autotuning
2: Static autotuning 1 (autotune totally)
3: Static autotuning 2 (autotune part   parameters)
P02.00
Type of motor 1
0: Asynchronous motor
1: Synchronous   motor
P02.01
Rated power of asynchronous motor 1
0.1–3000.0kW
Depend on model
P02.02
Rated frequency of asynchronous motor 1
0.01Hz–P00.03 (Max. output frequency)
50.00Hz
P02.03
Rated speed of asynchronous motor 1
1–36000rpm
Depend on model
P02.04
Rated voltage of asynchronous motor 1
0–1200V
Depend on model
P02.05
Rated current of asynchronous motor 1
0.8–6000.0A
Depend on model
P02.06
Stator resistor of asynchronous motor 1
0.001–65.535Ω
Depend on model
P02.07
Rotor resistor of asynchronous motor 1
0.001–65.535Ω
Depend on model
P02.08
Leakage inductance of asynchronous motor 1
0.1–6553.5mH
Depend on model
P02.09
Mutual inductance of asynchronous motor 1
0.1–6553.5mH
Depend on model
P02.10
Non-load current of asynchronous motor 1
0.1–6553.5A
Depend on model
P02.15
Rated power of synchronous motor 1
0.1–3000.0kW
Depend on model
P02.16
Rated frequency of synchronous motor 1
0.01Hz–P00.03 (Max. frequency)
50.00Hz
P02.17
Number of poles pairs for synchronous motor   1
1–50
P02.18
Rated voltage of synchronous motor 1
0–1200V
Depend on model
P02.19
Rated current of synchronous motor 1
0.8–6000.0A
Depend on model
P02.20
Stator resistor of synchronous motor 1
0.001–65.535Ω
Depend on model
P02.21
Direct axis inductance of synchronous motor   1
0.01–655.35mH
Depend on model
P02.22
Quadrature axis inductance of synchronous   motor 1
0.01–655.35mH
Depend on model
P02.23
Back EMF constant of synchronous motor 1
0–10000
300
P05.01–P05.09
Multi-function digital input terminals
(S1–S8, HDI) function selection
35: Shift   from motor 1 to motor 2
P08.31
Motor shifting
LED ones: shifting channel
0: terminal shifting
1: Modbus communication shifting
2: PROFIBUS/CANopen communication shifting
3: Ethernet communication shifting
4: Reserved
LED tens: shifting enabling in operation
0: Disabled
1: Enabled
0x00–0x14
00
P12.00
Motor type 2
P12.01
Rated power of asynchronous motor 2
0.1–3000.0kW
Depend on model
P12.02
Rated frequency of asynchronous motor 2
50.00Hz
P12.03
Rated speed of asynchronous motor 2
1–36000rpm
Depend on model
P12.04
Rated voltage of asynchronous motor 2
0–1200V
Depend on model
P12.05
Rated current of asynchronous motor 2
0.8–6000.0A
Depend on model
P12.06
Stator resistor of asynchronous motor 2
0.001–65.535Ω
Depend on model
P12.07
Rotor resistor of asynchronous motor 2
0.001–65.535Ω
Depend on model
P12.08
Leakage inductance of asynchronous motor 2
0.1–6553.5mH
Depend on model
P12.09
Mutual inductance of asynchronous motor 2
0.1–6553.5mH
Depend on model
P12.10
Non-load current of asynchronous motor 2
0.1–6553.5A
Depend on model
P12.15
Rated power of synchronous motor 2
0.1–3000.0kW
Depend on model
P12.16
Rated frequency of synchronous motor 2
50.00Hz
P12.17
Number of poles pairs for synchronous motor   2
1–50
P12.18
Rated voltage of synchronous motor 2
0–1200V
Depend on model
P12.19
Rated current of synchronous motor 2
0.8–6000.0A
Depend on model
P12.20
Stator resistor of synchronous motor 2
0.001–65.535Ω
Depend on model
P12.21
Direct axis inductance of synchronous motor   2
0.01–655.35mH
Depend on model
P12.22
Quadrature axis inductance of synchronous   motor 2
0.01–655.35mH
Depend on model
P12.23
Back EMF constant of synchronous motor 2
0–10000
300
