The start-up and stop control of the VFD includes three states: start after the running command during normal powering on, start after the restarting function becomes valid during normal powering on and start after the automatic fault reset. Below is the detailed instruction for three startings.
There are three starting methods for the VFD: start from the starting frequency directly, start after the AC braking and start after the rotation speed tracking. The user can select according to different situations to meet their needs.
For the load with big inertia, especially in the cases where the reverse rotation may occur, it is better to select starting after DC braking and then starting after rotation speed tracking.
Note: it is recommended to use the direct starting to drive synchronous motor.
1. The starting logic figure of starting after the running command during the normal powering on.
2. The starting logic figure of starting after the restarting function becomes valid during the normal powering on.
3. The starting logic figure of starting after the automatic fault reset.
 Related parameters
Function code
Default value
P00.01
Running command channel
0: Keypad
1: Terminal   ("LOCAL/REMOT"   flickering)
2: Communication   ("LOCAL/REMOT"   on)
P00.11
ACC time 1
0.0–3600.0s
Depend   on model
P00.12
DEC time 1
0.0–3600.0s
Depend   on model
P01.00
Start mode
0: Start-up   directly
1: Start-up   after DC braking
2: Start-up   after rotation speed tracking 1
P01.01
Starting frequency of direct start
0.00–50.00Hz
0.50Hz
P01.02
Retention time of the starting frequency
0.0–50.0s
0.0s
P01.03
The braking current before starting
0.0–100.0%
0.0%
P01.04
The braking time before starting
0.00–50.00s
0.00s
P01.05
ACC/DEC selection
0: Linear type
1:   Reserved
P01.08
Stop mode
0: Decelerate   to stop
1: Coast   to stop
P01.09
Starting frequency of DC braking
0.00Hz–P00.03 (Max. output   frequency)
0.00Hz
P01.10
Waiting time of DC braking
0.00–50.00s
0.00s
P01.11
DC braking current
0.0–100.0%
0.0%
P01.12
DC braking time
0.00–50.00s
0.00s
P01.13
Dead time of FWD/REV rotation
0.0–3600.0s
0.0s
P01.14
Shifting between FWD/REV rotation
Set the threshold   point of the VFD:
0: Switch after 0   frequency
1: Switch after the   starting frequency
2: Switch   after the speed reached P01.15 and delay of P01.24.
P01.15
Stopping speed
0.00–100.00Hz
0.50   Hz
P01.16
Detection of stopping speed
0: Speed setting   (the only detection method in SVPWM mode)
1: Speed detecting   value
P01.18
Terminal
running protection when powering on
0: The   terminal running command is invalid when powering on
1: The   terminal running command is valid when powering on
P01.19
Action if running frequency<lower limit   frequency
(valid when lower limit>0)
0: Run at the   lower-limit frequency
1: Stop
2:   Hibernation
P01.20
Hibernation restore delay time
0.0–3600.0s (valid when P01.19=2)
0.0s
P01.21
Restart after power outage
0: Disable
1: Enable
P01.22
Waiting time of restart after power outage
0.0–3600.0s (valid when P01.21=1)
1.0s
P01.23
Start delay time
0.0–60.0s
0.0s
P01.24
Delay time of the stop speed
0.0–100.0s
0.0s
P05.01–P05.09
Digital   input function selection
1: Forward   rotation operation
2: Reverse   rotation operation
4: Forward rotation jogging
5: Reverse rotation jogging
6: Coast to stop
7: Fault reset
8: Operation   pause
21: ACC/DEC time option1
22: ACC/DEC time option2
30: ACC/DEC   prohibition
P08.06
Jogging frequency
0.00Hz–P00.03 (Max. frequency)
5.00Hz
P08.07
Jogging ACC time
0.0–3600.0s
Depend   on model
P08.08
Jogging DEC time
0.0–3600.0s
Depend   on model
P08.00
ACC time 2
0.0–3600.0s
Depend   on model
P08.01
DEC time 2
0.0–3600.0s
Depend   on model
P08.02
ACC time 3
0.0–3600.0s
Depend   on model
P08.03
DEC time 3
0.0–3600.0s
Depend   on model
P08.04
ACC time 4
0.0–3600.0s
Depend   on model
P08.05
DEC time 4
0.0–3600.0s
Depend   on model
P08.28
Automatic fault reset times
0–10
P08.29
Interval time of automatic fault reset
0.1–3600.0s
1.0s
