Goodrive300 series VFDs can set the frequency by various means. The given channel can be divided into main given channel and assistant given channel.
There are two mian given channels: A frequency given channel and B frequency given channel. These two given channels can carry out mutual simple math calculation between each other. And the given channels can be shifted dynamically through set multi-funciton terminals.
There are three assistane given channels: keypad UP/DOWN input, terminals UP/DOWN switch input and digital potentiometer input. The three ways equal to the effect of input UP/DOWN given in internal assistant given of the VFD. The user can enable the given method and the effect of the method to the frequency given by setting function codes.
The actual given of the VFD is comsisted of main given channel and assistant given channel.
Goodrive300 series VFDs support the shifting between different given channels, and the detailed shifting rules are as below:
Current    given channel
P00.09
Multi-function    terminal function 13
Switch from    A channel to B channel
Multi-function    terminal function 14
Switch from    combination setting to A channel
Multi-function    terminal function 15
Switch from    combination setting to B channel
A
B
B
A
A+B
A
B
A-B
A
B
Max(A,B)
A
B
Min(A,B)
A
B
Note: "/" means the multi-function terminal is invalid under the current given channel.
When select multi-function terminal UP (10) and DOWN (11) to set the internal assistant frequency, P08.44 and P08.45 can be set to increase or decrease the set frequency quickly.
Related parameters
Function code
Default value
P00.03
Max. output frequency
P00.04–400.00Hz
50.00Hz
P00.04
Upper limit of the running frequency
P00.05–P00.03
50.00Hz
P00.05
Lower limit of the running frequency
0.00Hz–P00.04
0.00Hz
P00.06
A frequency command
0: Keypad
1: AI1
2: AI2
3: AI3
4: High-speed   pulse HDI
5: Simple   PLC program
6: Multi-step speed running
7: PID control
8: Modbus   communication
9: PROFIBUS/CANopen communication
10: Ethernet   communication
11: Reserved
P00.07
B frequency command
P00.08
B frequency command reference
0: Max. output frequency
1: A   frequency command
P00.09
Combination of setting sources
0: A
1: B
2: (A+B) combination
3: (A-B) combination
4: Max(A,B) combination
5: Min(A,B) combination
P05.01–P05.09
Multi-function   digital input terminals
(S1–S8, HDI) function selection
10: Increasing frequency setting (UP)
11: Decreasing frequency setting (DOWN)
12: Cancel the frequency change setting
13: Shift between A setting and B setting
14: Shift between combination setting and A   setting
15: Shift   between combination setting and B setting
P08.42
Keypad data control
0x000–0x1223
LED ones: frequency enable selection
0: Both ∧/∨ keys and digital potentiometer adjustments are valid
1: Only ∧/∨ keys adjustment is valid
2: Only digital potentiometer adjustments is valid
3: Neither ∧/∨ keys nor digital potentiometer adjustments   are valid
LED tens: frequency control selection
0: Only valid   when P00.06=0 or P00.07=0
1: Valid   for all frequency setting manner
2: Invalid   for multi-step speed when multi-step speed has the priority
LED hundreds: action selection during   stopping
0: Setting is valid
1: Valid during running, cleared after   stopping
2: Valid during running, cleared after   receiving the stop command
LED thousands: ∧/∨ keys and digital potentiometer Integral   function
0: The Integral function is valid
1: The Integral   function is invalid
0x0000
P08.43
Integral ratio of   the keypad potentiometer
0.01–10.00s
0.10s
P08.44
UP/DOWN terminals   control
0x00–0x221
LED ones: frequency control selection
0: UP/DOWN terminals setting valid
1: UP/DOWN terminals setting valid
1: All frequency means are valid
2: When the multi-step are priority, it is   invalid to the multi-step
LED hundreds: action selection when stop
0: Setting valid
1: Valid in the running, clear after stop
2: Valid in the running, clear after   receiving the stop commands
0x000
P08.45
UP terminals frequency changing ratio
0.01–50.00Hz/s
0.50 Hz/s
P08.46
DOWN terminals frequency changing ratio
0.01–50.00 Hz/s
0.50 Hz/s
P17.00
Setting frequency
Display   current set frequency of the VFD
Range: 0.00Hz–P00.03
0.00Hz
P17.02
Ramp reference frequency
Display   current ramp given frequency of the VFD.
0.00Hz
P17.14
Digital adjustment
Display the adjustment through the keypad of the VFD.
0.00V
