Goodrive300 series VFDs have three analog input terminals and 1 high-speed pulse input terminals (of which, AI1 and AI2 are 0–10V/0–20mA and Al can select voltage input or current input by J3, AI2 can select voltage input or current input by J4 and AI3 is for -10–10V) as the standard configuration. The inputs can be filtered and the maximum and minimum values can be adjusted.
Related parameters
Function code
Default value
P05.00
HDI input selection
0: High pulse input.
1: Digital input.
P05.32
Lower limit of AI1
0.00V–P05.34
0.00V
P05.33
Corresponding setting of the lower limit of   AI1
-100.0%–100.0%
0.0%
P05.34
Upper limit of AI1
P05.32–10.00V
10.00V
P05.35
the upper limit of AI1
-100.0%–100.0%
100.0%
P05.36
AI1 input filter time
0.000s–10.000s
0.100s
P05.37
Lower limit of AI2
0.00V–P05.39
0.00V
P05.38
Corresponding setting of the lower limit of   AI2
-100.0%–100.0%
0.0%
P05.39
Upper limit of AI2
P05.37–10.00V
10.00V
P05.40
the upper limit of AI2
-100.0%–100.0%
100.0%
P05.41
AI2 input filter time
0.000s–10.000s
0.100s
P05.42
Lower limit of
AI3
-10.00V–P05.44
-10.00V
P05.43
Corresponding setting of the lower limit of   AI3
-100.0%–100.0%
-100.0%
P05.44
Middle value of AI3
P05.42–P05.46
0.00V
P05.45
Corresponding middle setting of  AI3
-100.0%–100.0%
0.0%
P05.46
Upper limit of AI3
P05.44–10.00V
10.00V
P05.47
the upper limit of AI3
-100.0%–100.0%
100.0%
P05.48
AI3 input filter time
0.000s–10.000s
0.100s
P05.49
HDI high-speed pulse input function
selection
0: Frequency setting input, frequency   setting source
1: Counter input, high-speed pulse counter   input terminals
2: Length   counting input, length counter input terminals
P05.50
Lower limit frequency of HDI
0.000kHz–P05.52
0.000kHz
P05.51
Corresponding setting of HDI low frequency   setting
-100.0%–100.0%
0.0%
P05.52
Upper limit frequency of HDI
P05.50–50.000kHz
50.000
kHz
P05.53
Corresponding setting of upper limit   frequency of HDI
-100.0%–100.0%
100.0%
P05.54
HDI frequency input filter time
0.000s–10.000s
0.100s
