Goodrive300 series VFDs have 2 analog output terminals (0–10V or 0–20mA) and 1 high speed pulse output terminal. Analog output signal can be filtered and the maximum and minimum values can be adjusted. The analog output signals can be proportional to motor speed, output frequency, output current, motor torque, motor power, etc.
Output instructions:
Set    value
Function
Instructions
Running frequency
0–the Max. output   frequency
Set frequency
Ramp frequency   reference
3
Running speed
0–2 times   of the rated synchronous rotation speed of the motor
4
Output current (corresponding   to the VFD)
0–2 times   of the rated current of the VFD
5
Output current (corresponding   to the motor)
6
Output voltage
0–1.5   times of the rated voltage of the VFD
7
Output power
0–2 times   of the rated power
8
Setting torque value
0–2 times   of the rated current of the motor
9
Output torque
10
AI1
0–10V/0–20mA
11
AI2
0–10V/0–20mA
12
AI3
-10V–10V
13
HDI
0.00–50.00kHz
14
Setting value 1 of Modbus communication
-1000–1000,1000 corresponds to 100.0%
15
Set value 2 of Modbus communication
16
Setting value 1 of PROFIBUS/CANOPEN communication
17
Setting value 2 of PROFIBUS/CANOPEN communication
-1000–1000,100 corresponds to 100.0%
18
Setting value 1 of Ethernet communication
19
Setting value 2 of Ethernet communication
20–21
Reserved
22
Torque current (corresponding to the rated current of the motor)
23
Exciting current (corresponding to the rated current of the motor)
24–30
Reserved
Related parameters
Function code
Default value
P06.00
HDO output
0: Open collector high speed pulse output
1: Open   collector output
P06.14
AO1 output
0: Running frequency
1: Set frequency
2: Ramp reference frequency
3: Running rotation speed (relative to 2   times the synchronous rotation speed of the motor)
4: Output current (relative to 2 times the   rated current of the VFD)
5: Output current (relative to 2 times the   rated current of the motor)
6: Output voltage (relative to 1.5 times   the rated voltage of the VFD)
7: Output power  (relative to 2 times the rated power of the   motor)
8: Set torque value (relative to 2 times   the rated torque of the motor)
9: Output torque (relative to 2 times the   rated torque of the motor)
10: Analog AI1 input   value
11: Analog AI2 input   value
12: Analog AI3 input   value
13: Input value   of high-speed pulse HDI
14: Modbus communication set value 1
15: Modbus communication set value 2
16: Set value 1 of PROFIBUS/CANopen   communication
17: Set value 2 of PROFIBUS/CANopen   communication
18: Set value 1 of Ethernet communication
19: Set value 2 of Ethernet communication
20–21: Reserved
22: Torque current (corresponding to triple   the rated current of the motor)
23: Ramp reference frequency (with sign)
24–30:   Reserved
P06.15
AO2 output
P06.16
HDO high-speed pulse output
P06.17
Lower output limit of AO1
-100.0%–P06.19
0.0%
P06.18
Corresponding AO1 output of lower limit
0.00V–10.00V
0.00V
P06.19
Upper output limit of AO1
P06.17–100.0%
100.0%
P06.20
The corresponding AO1 output of upper limit
0.00V–10.00V
10.00V
P06.21
AO1 output filter time
0.000s–10.000s
0.000s
P06.22
Lower output limit of AO2
-100.0%–P06.24
0.0%
P06.23
Corresponding AO2 output of lower limit
0.00V–10.00V
0.00V
P06.24
Upper output limit of AO2
P06.22–100.0%
100.0%
P06.25
The corresponding AO2 output of upper limit
0.00V–10.00V
10.00V
P06.26
AO2 output filter time
0.000s–10.000s
0.000s
P06.27
Lower output limit of HDO
-100.0%–P06.29
0.00%
P06.28
Corresponding HDO output of lower limit
0.00–50.00kHz
0.0kHz
P06.29
Upper output limit of HDO
P06.27–100.0%
100.0%
P06.30
Corresponding HDO output of upper limit
0.00–50.00kHz
50.00kHz
P06.31
HDO output filter time
0.000s–10.000s
0.000s
