Function    code
Default    value
Modify
P16.00
Speed setting of the   Ethernet communication
0: Self-adapting
1: 100M full duplex
2: 100M semiduplex
3: 10M full duplex
4: 10M semiduplex
The function code   is used to set the Ethernet communication speed.
P16.01
IP address 1
0–255
Set the IP address   of Ethernet communication.
The format of IP address: P16.09.P16.10.P16.11.P16.12.
For example: IP address is 192.168.0.1.
192
P16.02
IP address 2
168
P16.03
IP address 3
P16.04
IP address 4
P16.05
Subnet mask 1
0–255
Set the subnet mask   of Ethernet communication.
The format of IP   subnet mask: P16.13.P16.14.P16.15.P16.16.
For example: The   mask is 255.255.255.0.
255
P16.06
Subnet mask 2
255
P16.07
Subnet mask 3
255
P16.08
Subnet mask 4
P16.09
Gateway 1
0–255
Set the gateway of   Ethernet communication.
192
P16.10
Gateway 2
168
P16.11
Gateway 3
P16.12
Gateway 4
