P17.00
Setting frequency
Display   current set frequency of the VFD.
Range: 0.00Hz–P00.03
0.00Hz
P17.01
Output frequency
Display   current output frequency of the VFD.
0.00Hz
P17.02
Ramp reference   frequency
Display   current ramp given frequency of the VFD.
0.00Hz
P17.03
Output voltage
Display   current output voltage of the VFD.
Range: 0–1200V
0V
P17.04
Output current
Display   current output current of the VFD.
Range: 0.0–3000.0A
0.0A
P17.05
Motor speed
Display   the rotation speed of the motor.
Range: 0–65535RPM
0 RPM
P17.06
Torque current
Display   current torque current of the VFD.
Range: -3000.0–3000.0A
0.0A
P17.07
Exciting current
Display   current exciting current of the VFD.
0.0A
P17.08
Motor power
Display   current power of the motor.
Setting range: -300.0%–300.0%
(the   rated current of the motor)
0.0%
P17.09
Output torque
Display   the current output torque of the VFD.
Range: -250.0–250.0%
0.0%
P17.10
Evaluated motor   frequency
Evaluate   the motor rotor frequency on close loop vector.
Range: 0.00– P00.03
0.00Hz
P17.11
DC bus voltage
Display   current DC bus voltage of the VFD.
Range: 0.0–2000.0V
0.0V
P17.12
Digital input   terminals state
Display   current Switch input terminals state of the VFD.
Range: 0000–01FF
P17.13
Digital output   terminals state
Display   current Switch output terminals state of the VFD.
Range: 0000–000F
P17.14
Digital adjustment
Display   the adjustment through the keypad of the VFD.
0.00Hz
P17.15
Torque reference
Display   the torque given, the percentage to the current rated torque of the motor.
Setting range: -300.0%–300.0% (the   rated current of the motor)
0.0%
P17.16
Linear speed
Display   the current linear speed of the VFD.
Range: 0–65535
P17.17
Length
Display   the current length of the VFD.
Range: 0–65535
P17.18
Count value
Display   the current counting number of the VFD.
Range: 0–65535
P17.19
AI1 input voltage
Display   analog AI1 input signal.
Range: 0.00–10.00V
0.00V
P17.20
AI2 input voltage
Display   analog AI2 input signal.
Range: 0.00–10.00V
0.00V
P17.21
AI3 input voltage
Range: -10.00–10.00V
0.00V
P17.22
HDI input frequency
Display   HDI input frequency.
Range: 0.000–50.000kHz
0.000
kHz
P17.23
PID reference
Display   PID given value.
Range: -100.0–100.0%
0.0%
P17.24
PID feedback
Display   PID response value.
0.0%
P17.25
Power factor of the   motor
Display   the current power factor of the motor.
Range: -1.00–1.00
0.0
P17.26
Current running time
Display   the current running time of the VFD.
Range:0–65535m
0m
P17.27
Simple PLC and the   current step of the multi-step speed
Display simple   PLC and the current stage of the multi-step speed.
Range: 0–15
P17.28
ASR controller   output
The   percentage of the rated torque of the corresponding motor, display ASR   controller output.
Range: -300.0%–300.0% (the rated current of the   motor)
0.0%
P17.29
Magnetic pole angle   of SM
Display   synchronous motor Magnetic pole angle.
Range: 0.0–360.0
0.0
P17.30
Phase compensation   of SM
Display   synchronous motor phase compensation.
Range: -180.0–180.0
0.0
P17.31
High-frequency   superimposed current of SM
Display   synchronous motor high-frequency Superimposed current.
Range: 0.0%–200.0% (the rated current of the   motor)
0.0
P17.32
Magnetic flux   linkage
Display   the magnetic flux linkage of the motor.
Range: 0.0%–200.0%
0.0%
P17.33
Exciting current reference
Display the exciting current reference in the vector control mode.
0.0A
P17.34
Torque current reference
Display the torque current reference in the vector control mode.
0.0A
P17.35
AC current
Display the value of inlet current in AC   side.
Range: 0.0–5000.0A
0.0A
P17.36
Output torque
Display the output torque. Positive value is in the   electromotion state, and negative is in the power generating state.
Range : -3000.0Nm–3000.0Nm
0.0Nm
P17.37
Count value of motor   overload
0–100 (100 reports OL1   fault)
P17.38
PID   output
-100.00–100.00%
0.00%
P17.39
Wrong   download of parameters
0.00–99.99
0.00
