The type designation contains information on the VFD. The user can find the type designation on the type designation label attached to the VFD or the simple name plate.
Figure 3-5 Product type
Key | No. | Detailed description | Detailed content |
Abbreviation | ① | Product abbreviation | GD310 is shorted for Goodrive310 |
Rated power | ② | Power range + Load type | 022: 22kW G: Constant torque load P: Constant power load |
Voltage degree | ③ | Voltage degree | 2: AC 3PH 200V–240V Rated voltage: 220V 4: AC 3PH 380V–480V Rated voltage: 460V 6: AC 3PH 520V–600V Rated voltage: 575V |
Certification mark | ④ | Used in America | Certified by UL and CUL |
