Model | Rated output power (kW) | Rated input current (A) | Rated output current (A) |
GD310-0R7G-2-UL | 0.75 | 5 | 4.5 |
GD310-1R5G-2-UL | 1.5 | 7.7 | 7 |
GD310-2R2G-2-UL | 2.2 | 11 | 10 |
GD310-004G-2-UL | 4 | 17 | 16 |
GD310-5R5G-2-UL | 5.5 | 21 | 20 |
GD310-7R5G-2-UL | 7.5 | 31 | 30 |
GD310-011G-2-UL | 11 | 43 | 42 |
GD310-015G-2-UL | 15 | 56 | 55 |
GD310-018G-2-UL | 18.5 | 71 | 70 |
GD310-022G-2-UL | 22 | 81 | 80 |
GD310-030G-2-UL | 30 | 112 | 110 |
GD310-037G-2-UL | 37 | 132 | 130 |
GD310-045G-2-UL | 45 | 163 | 160 |
GD310-055G-2-UL | 55 | 200 | 200 |
1. The input current of VFDs 0.75–55kW is detected when the input voltage is 220V and there is no DC reactors and input/output reactors.
2. The rated output current is defined when the output voltage is 220V.
3. The output current cannot exceed the rated output current and the output power cannot exceed the rated output power in the voltage range.
GD310-1R5G-4-UL | 1.5 | 5.0 | 3.7 |
GD310-2R2G-4-UL | 2.2 | 5.8 | 5.0 |
GD310-004G-4-UL | 4 | 13.5 | 9.5 |
GD310-5R5G-4-UL | 5.5 | 19.5 | 14 |
GD310-7R5G-4-UL | 7.5 | 25 | 18.5 |
GD310-011G-4-UL | 11 | 32 | 25 |
GD310-015G-4-UL | 15 | 40 | 32 |
GD310-018G-4-UL | 18.5 | 47 | 38 |
GD310-022G-4-UL | 22 | 56 | 45 |
GD310-030G-4-UL | 30 | 70 | 60 |
GD310-037G-4-UL | 37 | 80 | 75 |
GD310-045G-4-UL | 45 | 94 | 92 |
GD310-055G-4-UL | 55 | 128 | 115 |
GD310-075G-4-UL | 75 | 160 | 150 |
GD310-090G-4-UL | 90 | 190 | 180 |
GD310-110G-4-UL | 110 | 225 | 215 |
GD310-132G-4-UL | 132 | 265 | 260 |
GD310-160G-4-UL | 160 | 310 | 305 |
GD310-185G-4-UL | 185 | 345 | 340 |
GD310-200G-4-UL | 200 | 385 | 380 |
GD310-220G-4-UL | 220 | 430 | 425 |
GD310-250G-4-UL | 250 | 485 | 480 |
GD310-280G-4-UL | 280 | 545 | 530 |
GD310-315G-4-UL | 315 | 610 | 600 |
GD310-350G-4-UL | 350 | 625 | 650 |
GD310-400G-4-UL | 400 | 715 | 720 |
GD310-500G-4-UL | 500 | 890 | 860 |
GD310-5R5P-4-UL | 5.5 | 19.5 | 14 |
GD310-7R5P-4-UL | 7.5 | 25 | 18.5 |
GD310-011P-4-UL | 11 | 32 | 25 |
GD310-015P-4-UL | 15 | 40 | 32 |
GD310-018P-4-UL | 18.5 | 47 | 38 |
GD310-022P-4-UL | 22 | 56 | 45 |
GD310-030P-4-UL | 30 | 70 | 60 |
GD310-037P-4-UL | 37 | 80 | 75 |
GD310-045P-4-UL | 45 | 94 | 92 |
GD310-055P-4-UL | 55 | 128 | 115 |
GD310-075P-4-UL | 75 | 160 | 150 |
GD310-090P-4-UL | 90 | 190 | 180 |
GD310-110P-4-UL | 110 | 225 | 215 |
GD310-132P-4-UL | 132 | 265 | 260 |
GD310-160P-4-UL | 160 | 310 | 305 |
GD310-185P-4-UL | 185 | 345 | 340 |
GD310-200P-4-UL | 200 | 385 | 380 |
GD310-220P-4-UL | 220 | 430 | 425 |
GD310-250P-4-UL | 250 | 485 | 480 |
GD310-280P-4-UL | 280 | 545 | 530 |
GD310-315P-4-UL | 315 | 610 | 600 |
GD310-350P-4-UL | 350 | 625 | 650 |
GD310-400P-4-UL | 400 | 715 | 720 |
GD310-500P-4-UL | 500 | 890 | 860 |
1. The input current of VFDs (G-type: 1.5–200kW, P-type: 5.5–220kW) is detected when the input voltage is 460V and there is no DC reactors and input/output reactors.
2. The input current of VFDs (G-type: 220–500kW, P-type: 250–500kW) is detected when the input voltage is 460V and there are input reactors.
3. The rated output current is defined when the output voltage is 460V.
4. The output current cannot exceed the rated output current and the output power cannot exceed the rated output power in the voltage range.
GD310-018G-6-UL | 18.5 | 35 | 27 |
GD310-022G-6-UL | 22 | 40 | 35 |
GD310-030G-6-UL | 30 | 47 | 45 |
GD310-037G-6-UL | 37 | 52 | 52 |
GD310-045G-6-UL | 45 | 65 | 62 |
GD310-055G-6-UL | 55 | 85 | 86 |
GD310-075G-6-UL | 75 | 95 | 98 |
GD310-090G-6-UL | 90 | 118 | 120 |
GD310-110G-6-UL | 110 | 145 | 150 |
1. The input current of VFDs 18.5–110kW is detected when the input voltage is 575V and there is no DC reactors and input/output reactors.
2. The rated output current is defined when the output voltage is 575V.
