Below is the layout figure of the VFD (take the VFD of 460V G-type 30kW as the example).
Figure 3-6 Product structure
Serial No.
Illustration
Keypad port
Connect the keypad
Upper cover
Protect the internal parts and components
3
Keypad
See Keypad operation procedure for detailed information
4
Cooling fan
See Maintenance and hardware diagnostics for detailed information
5
Wiring port
Connect to the control board and the drive board
6
Name plate
See Product Overview for detailed information
7
Side cover
Optional. The side cover will increase   the protective degree of the VFD. The internal temperature of the VFD will increase, too, so it is necessary to derate the VFD at the same time
8
Control terminals
See Installation guidelines for detailed information
9
Main circuit   terminals
10
Main circuit cable port
Fix the main circuit cable
11
POWER light
Power indicator
12
Simple name plate
See Type designation key for detailed information
13
Lower cover
