Check before powering on
Please check according to the installation list in chapter two.
Original powering operation
Check to ensure there is no mistake in wiring and power supply, switch on the air switch of the AC power supply on the input side of the VFD to power on the VFD. 8.8.8.8.8. will be displayed on the keypad, and the contactor closes normally. When the character on the nixie tubs changes to the set frequency, the VFD has finished the initialization and it is in the stand-by state.
Below diagram shows the first operation: (take motor 1 as the example)
Note: If fault occurs, please do as the Fault Tracking. Estimate the fault reason and settle the issue.
Besides P00.01 and P00.02, terminal command setting can also be used to set the running command channel.
Current running command    channel
P00.01
Multi-function terminal  36
Switch to keypad
Multi-function terminal  37
Switch to to terminal
Multi-function terminal  38
Switch to to    communication
Keypad running command channel
Terminal running command channel
Communication running command channel
Note: / means the multi-function terminal is invalid on the current given channel.
Relative parameters table:
Function code
Default value
P00.00
Speed control mode
0: Sensorless vector control mode 0 (apply to AM and SM)
1: Sensorless vector control mode 1   (applying to AM)
2: SVM control
P00.01
Run command channel
0: Keypad running command
1: Terminal running command channel (“LOCAL/REMOT” flickering)
2: Communication running command channel (“LOCAL/REMOT”   on);
P00.02
Communication running commands
0: MODBUS communication channel
1: PROFIBUS\CANopen communication channel
2: Ethernet communication channel
3: Reserved
P00.18
Function
restore parameter
0: No operation
1: Restore the default value
2: Cancel the fault record
P00.15
Motor parameter autotuning
0: No operation
1: Rotating autotuning
2: Static autotuning 1 (autotune   totally)
3: Static autotuning 2 (autotune part of the parameters)
P02.00
Motor type 1
0: Asynchronous motor
1: Synchronous motor
P02.01
Rated power of asynchronous motor 1
0.1–3000.0kW
Depend on model
P02.02
Rated frequency of asynchronous motor 1
0.01Hz–P00.03 (the max frequency)
60.00Hz
P02.03
Rated speed of asynchronous motor 1
1–36000rpm
Depend on model
P02.04
Rated voltage of asynchronous motor 1
0–1200V
Depend on model
P02.05
Rated current of asynchronous motor 1
0.8–6000.0A
Depend on model
P02.15
Rated power of synchronous motor 1
0.1–3000.0kW
Depend on model
P02.16
Rated frequency of synchronous motor 1
60.00Hz
P02.17
Number of poles pairs for   synchronous motor 1
1–50
P02.18
Rated voltage of synchronous motor 1
0–1200V
Depend on model
P02.19
Rated current of synchronous motor 1
0.8–6000.0A
Depend on model
P05.01–P05.09
Multi-function digital input terminals
(S1–S8, HDI) function selection
36: Shift the command to keypad
37: Shift the command to terminals
38: Shift the command to communication
P07.01
Parameter copy
The function code determines   the manner of parameters copy.
0: No operation
1: Upload the local function   parameter to the keypad
2: Download the keypad function   parameter to local address (including the motor parameters)
3: Download the keypad function   parameter to local address (excluding the motor parameter of P02 and P12 group)
4: Download the keypad function   parameters to local address (only for the motor parameter of P02 and P12 group)
P07.02
QUICK/JOG   function selection
0: No function
1: Jogging
2: Shift the display state by the shifting key
3: Shift between forward   rotations and reverse rotations
4: Clear UP/DOWN settings
5: Coast to stop
6: Shift the given manner of running commands
7: Quick commissioning mode (committee according to the non-factory parameter)
