Because asynchronous motors have the characteristics of high stage, nonlinear, strong coupling and various variables, the actual control of the asynchronous motor is very difficult. Vector control is mainly used to settle this problem with the theme of that divide the stator current vector into exciting current (the current heft generating internal magnetic field of the motor) and torque current (the current heft generating torque) by controlling and measuring the stator current vector according to the principles of beamed magnetic field to control the range and phase of these two hefts. This method can realize the decoupling of exciting current and torque current to adjust the high performance of asynchronous motors.
Goodrive310-UL series VFDs are embedded with speed sensor-less vector control calculation for driving both asynchronous motors and synchronous motors. Because the core calculation of vector control is based on exact motor parameter models, the accuracy of motor parameter will impact on the performance of vector control. It is recommended to input the motor parameters and carry out autotune before vector running.
Because the vector control calculation is very complicated, high technical theory is needed for the user during internal autotune. It is recommended to use the specific function parameters in vector control with cautions.
Function code
Default value
P00.00
Speed control mode
0: Sensorless vector control mode 0 (apply to AM and SM)
1: Sensorless vector control mode 1 (applying to AM)
2: SVM control
P00.15
Motor parameter autotuning
0: No operation
1: Rotating autotuning
2: Static autotuning 1 (autotune totally)
3: Static autotuning 2 (autotune part of the parameters)
P02.00
Motor type 1
0: Asynchronous motor
1: Synchronous motor
P03.00
Speed loop proportional gain1
0–200.0
20.0
P03.01
Speed loop integral time1
0.000–10.000s
0.200s
P03.02
Low switching
frequency
0.00Hz–P03.05
5.00Hz
P03.03
Speed loop proportional gain 2
0–200.0
20.0
P03.04
Speed loop integral time 2
0.000–10.000s
0.200s
P03.05
High switching
frequency
P03.02–P00.03 (the max frequency)
10.00Hz
P03.06
Speed loop output filter
0–8 (corresponds to 0–28/10ms)
P03.07
Compensation coefficient of electromotion slip
50%–200%
100%
P03.08
Compensation coefficient of braking slip
50%–200%
100%
P03.09
Current loop percentage coefficient P
0–65535
1000
P03.10
Current loop integral coefficient 1
0–65535
1000
P03.11
Torque setting method
This parameter is used to enable the torque control mode, and set the torque.
0: Torque control is invalid
1: Keypad setting torque (P03.12)
2: Analog AI1 setting torque
3: Analog AI2 setting torque
4: Analog AI3 setting torque
5: Pulse frequency HDI setting torque
6: Multi-step torque setting
7: MODBUS communication setting torque
8: PROFIBUS/CANopen communication setting torque
9: Ethernet communication setting torque
10: Reserved
P03.12
-300.0%–300.0% (rated motor current)
50.0%
P03.13
Torque reference filter time
0.000–10.000s
0.010s
P03.14
Upper frequency of forward rotation in vector control
0: Keypad (P03.16 sets P03.14, P03.17 sets P03.15)
1: AI1
2: AI2
3: AI3
4: Pulse frequency HDI setting upper-limit frequency
5: Multi-step setting upper-limit frequency
6: MODBUS communication setting upper-limit frequency
7: PROFIBUS/CANopen communication setting upper-limit frequency
8: Ethernet communication setting upper-limit frequency
9: Reserved
P03.15
Upper frequency of reverse rotation in vector control
P03.16
Keypad setting for upper frequency of forward rotation
Setting range: 0.00Hz–P00.03
(the max frequency)
60.00Hz
P03.17
Keypad setting for upper frequency of reverse rotation
60.00Hz
P03.18
Upper electromotion torque source
0: Keypad setting upper-limit frequency (P03.20 sets P03.18, P03.21 sets P03.19)
1: AI1
2: AI2
3: AI3
4: HDI
5: MODBUS communication
6: PROFIBUS/CANopen communication
7: Ethernet communication
8: Reserved
P03.19
Upper braking torque source
P03.20
Keypad setting of electromotion torque
0.0–300.0% (rated current of the motor)
180.0%
P03.21
Keypad setting of braking torque
180.0%
P03.22
Flux weakening coefficient in constant power zone
0.1–2.0
0.3
P03.23
Lowest flux weakening point in constant power zone
10%–100%
20%
P03.24
Max. voltage limit
0.0–120.0%
100.0%
P03.25
Pre-exciting time
0.000–10.000s
0.300s
P17.32
Magnetic flux linkage
0.0200.0%
