Goodrive310-UL series VFDs have 2 analog output terminals (010V or 020mA) and 1 high speed pulse output terminal. Analog output signal can be filtered and the maximum and minimum values can be adjusted. The analog output signals can be proportional to motor speed, output frequency, output current, motor torque, motor power, etc.
Output instructions:
Set value
Function
Instructions
Running frequency
0–the max output frequency
Set frequency
0– the max output frequency
Ramp given frequency
3
Running speed
0–2 times of the rated synchronous rotation speed of the motor
4
Output current (relative to the VFD)
0–2 times of the rated current of the VFD
5
Output current (relative to the motor)
6
Output voltage
0–1.5 times of the rated voltage of the VFD
7
Output power
0–2 times of the rated power
8
Setting torque value
0–2 times of the rated current of the motor
9
Output torque
10
AI1
0–10V/0–20mA
11
AI2
0–10V/0–20mA
12
AI3
-10V–10V
13
HDI
0.00–50.00kHz
14
Setting value 1 of MODBUS communication
-1000–1000, 1000 corresponds to 100.0%
15
Setting value 2 of MODBUS communication
16
Setting value 1 of PROFIBUS/CANOPEN communication
17
Setting value 2 of PROFIBUS/CANOPEN communication
-1000–1000, 100 corresponds to 100.0%
18
Setting value 1 of Ethernet communication
19
Setting value 2 of Ethernet communication
20–21
Reserved
22
Torque current (relative to the rated current of the motor)
23
Exciting current (relative to the rated current of the motor)
24–30
Reserved
Related parameters list:
Function code
Default value
P06.00
HDO output
0: Open collector pole high speed pulse output
1: Open collector pole output.
P06.14
AO1 output
0: Running frequency
1: Set frequency
2: Ramp reference frequency
3: Running rotation speed
4: Output current
(relative to the rated current of the VFD)
5: Output current
6: Output voltage
7: Output power
8: Set torque value
9: Output torque
10: AI1 input value
11: AI2 input value
12: AI3 input value
13: High speed pulse HDI input value
14: MODBUS communication set value 1
15: MODBUS communication set value 2
16: PROFIBUS/CANopen communication set value 1
17: PROFIBUS/CANopen communication set value 2
18: Ethernet communication set value 1
19: Ethernet communication set value 2
20–21: Reserved
22: Torque current (relative to the rated current of the motor)
23: Pre-magnetizing current (relative to the rated current of the motor)
24–30: Reserved
P06.15
AO2 output
P06.16
HDO high-speed pulse output
P06.17
Lower output limit of AO1
-100.0%–P06.19
0.0%
P06.18
Corresponding AO1 output of lower limit
0.00V–10.00V
0.00V
P06.19
Upper output limit of AO1
P06.17–100.0%
100.0%
P06.20
The corresponding AO1 output of upper limit
0.00V–10.00V
10.00V
P06.21
AO1 output filter time
0.000s–10.000s
0.000s
P06.22
Lower output limit of AO2
-100.0%–P06.24
0.0%
P06.23
Corresponding AO2 output of lower limit
0.00V–10.00V
0.00V
P06.24
Upper output limit of AO2
P06.22–100.0%
100.0%
P06.25
The corresponding AO2 output of upper limit
0.00V–10.00V
10.00V
P06.26
AO2 output filter time
0.000s–10.000s
0.000s
P06.27
Lower output limit of HDO
-100.0%–P06.29
0.00%
P06.28
Corresponding HDO output of lower limit
0.00–50.00kHz
0.0kHz
P06.29
Upper output limit of HDO
P06.27–100.0%
100.0%
P06.30
Corresponding HDO output of upper limit
0.00–50.00kHz
50.00kHz
P06.31
HDO output filter time
0.000s–10.000s
0.000s
