Motor type
Asynchronous induction motor or synchronous permanent magnet motor
Voltage
0 to U1, 3-phase symmetrical, Umax at the field weakening point
Short-circuit protection
The motor output is short-circuit proof by IEC 61800-5-1
Frequency
0...400Hz
Frequency resolution
0.01Hz
Current
Refer to Ratings
Power limit
1.5·PN
Field weakening point
10...400Hz
Carrier frequency
4, 8, 12 or 15kHz
B.4.1 EMC compatibility and motor cable length
To comply with the European EMC Directive (standard IEC/EN 61800-3), use the following maximum motor cable lengths for 4kHz switching frequency.
All frame sizes (with external EMC filter)
Maximum motor cable length, 4kHz
Second environment (category C3)
30
First environment (category C2)
30
Maximum motor cable length is determined by the drive’s operational factors. Contact the local representative for the exact maximum lengths when using external EMC filters.
