A model designation code contains product information. You can find the model designation code on the VFD nameplate and simplified nameplate.
Field | No. | Description | Content |
Abbreviation of product series | ① | Abbreviation of product series | GD350A: Goodrive350A series high-performance multifunction VFD |
Rated power | ② | Power range + load type | 5R5-5.5kW G: Constant torque load P: Variable torque load |
Voltage class | ③ | Voltage class | 4: AC 3PH 380V(-15%)–440V(+10%) |
Note: Braking units have been built in the 037G/045P and lower models as standard configuration. Braking units are not standard configuration for the 045G/055P–055G/075P models. (If you want to use braking units for these models, add suffix "-B" at the end of the model codes in your purchase orders, for example, GD350A-045G/055P-4-B.) |
