To ease function parameter settings on the keypad, function group numbers correspond to level-1 menus, function codes correspond to level-2 menus, and function parameters correspond to level-3 menus.
The columns in the function parameter tables in this chapter are described as follows:
  • Column 1 "Function code": function group and parameter code
  • Column 2 "Name": full name of a function parameter.
  • Column 3 "Description": Description of a function parameter
  • Column 4 "Setting range": setting range of a function parameter
  • Column 5 "Default ": factory setting for a function parameter
