4.2.1 Installation environment
Installation environment is essential for the VFD to operate at its best in the long run. The installation environment of the VFD should meet the following requirements.
Environment | Condition |
Installation site | Indoors |
Ambient temperature |
Humidity |
Storage temperature | -30–+60°C |
Running environment | The installation site should meet the following requirements.
Altitude |
Vibration | The max. amplitude of vibration should not exceed 5.8m/s2 (0.6g) |
Installation direction | Install the VFD vertically to ensure good heat dissipation effect |
Note: GD350 IP54 series VFDs must be installed in ventilated environments free of corrosive gases and conductive dust.
4.2.2 Installation direction
The VFD can be installed on the wall or in a cabinet.
The VFD must be installed vertically. Check the installation position according to following requirements. See Appendix C "Dimension drawings" for detailed outline dimensions.
Figure 4–1 Installation direction of the VFD
4.2.3 Installation mode
The VFDs can be installed in two modes, depending on the different VFD dimensions:
Figure 4–2 Installation mode
(1) Mark the position of the installation hole. See Appendix C "Dimension drawings" for the position of installation hole;
(2) Mount the screws or bolts onto the designated position;
(3) Put the VFD on the wall;
(4) Tighten the fixing screws on the wall.
Note: Flange-mounting plate is a must for 004G/5R5P-110G/132P VFDs that adopt flange-mounting mode.
4.2.4 Single-unit installation
Figure 4–3 Single-unit installation
Note: The min. dimension of B and C is 100mm.
4.2.5 Multiple-unit installation
Figure 4–4 Parallel installation
1. When users install VFDs in different sizes, align the top of each VFD before installation for the convenience of future maintenance.
2. The min dimension of B and C is 100mm, and the dimention of D can be 0, that is zero-clearance parallel installation is supported.
4.2.6 Vertical installation
Figure 4–5 Vertical installation
Note: During vertical installation, users must install windshield, otherwise, the VFD will experience mutual interference, and the heat dissipation effect will be degraded.
4.2.7 Tilted installation
Figure 4–6 Tilted installation
Note: During tilted installation, it is a must to ensure the air inlet duct and air outlet duct are separated from each other to avoid mutual interference.
