Function
Specification
Power input
Input voltage (V)
AC 3PH   380 V (-15%)–440 V (+10%)
Rated   voltage: 380 V
AC 3PH   520 V (-15%)–690 V (+10%)
Rated   voltage: 660 V
Input current (A)
Refer to   section 3.6 "Rated values"
Input frequency (Hz)
50 Hz or 60   Hz
Allowed   range: 47–63 Hz
Power output
Output voltage (V)
0–input   voltage
Output current (A)
Output power (kW)
Output frequency (Hz)
0–400 Hz
Technical control feature
Control mode
SVPWM, SVC   and VC
Motor type
Asynchronous   motor and permanent magnet synchronous motor
Adjustable-speed ratio
Asynchronous   motor 1: 200 (SVC) synchronous motor 1: 20 (SVC) 1: 1000 (VC)
Speed control accuracy
±0.2% (SVC)   ±0.02% (VC)
Speed fluctuation
± 0.3% (SVC)
Torque response
<20 ms   (SVC), <10 ms (VC)
Torque control accuracy
10% (SVC),   5% (VC)
Starting torque
Asynchronous   motor: 0.25 Hz/150% (SVC)
Synchronous   motor: 2.5 Hz/150% (SVC)
0 Hz/200%   (VC)
Overload capability
150% of rated   current: 1 minute
180% of rated   current: 10 seconds
200% of rated   current: 1 second
Running control feature
Frequency setting method
Digital setting, analog setting, pulse frequency   setting, multi-step speed running setting, simple PLC setting, PID setting, Modbus   communication setting, and PROFIBUS communication setting.
Switch between the combination and single setting channel
Auto-adjustment of the voltage
Keep constant voltage automatically when the grid   voltage transients
Fault protection
Provide more than 30 fault protection functions: overcurrent,   overvoltage, undervoltage, overheating, phase loss and overload, etc.
Restart after rotating   speed tracking
Smooth starting of the rotating motor
Note: Only for the VFD≥4 kW
Peripheral interface
Terminal analog input resolution
≤ 20 mV
Terminal switch input resolution
≤ 2 ms
Analog input
2 (AI1, AI2) 0–10 V/0–20 mA and 1 (AI3) -10–10 V
Analog output
2 (AO1, AO2)   0–10 V/0–20 mA
Digital input
8 common   inputs, the Max frequency: 1 kHz, internal impedance: 3.3 kΩ;
1 high   speed input, the Max frequency: 50 kHz
Digital output
1 high   speed pulse output, the Max frequency: 50 kHz;
1 Y   terminal open collector output
Relay output
2   programmable relay outputs
RO1A NO, RO1B   NC, RO1C common terminal
RO2A NO, RO2B   NC, RO2C common terminal
Contactor   capability: 3 A/AC 250 V,1 A/DC 30 V
Spindle stopping
For   spindle positioning and control sequence
Internal   7 scale marks and 4 zero marks
Position reference
External   zero-position detection switch positioning
Encoder Z   phase positioning
Servo control
Pulse   train reference: position control
Frequency division output
Encoder   frequency division output
 (H1 and H2 VFDs)
Speed/position mode
Terminal   shifting
Encoder
C1 support 100 kHz, D1 support 500 kHz, H1 support 300   kHz and H2 support 400 kHz
Positioning
Pulse Z and photoelectric switch positioning.   Positioning is accurate without overmodulation.
Others
Mountable method
Wall, flange   and floor mountable
Temperature of the running environment
-10–50°C,   if temperature is above 40°C, derate 1% for every additional 1°C.
Average non-fault time
2 years (25°C   ambient temperature)
Protective degree
IP20
Pollution level
Level 2
Cooling
Air-cooling
Brake unit
Built-in   for VFDs of 380 V (≤30 kW)
External   for others
EMC filter
All   products of the 380V series meet the IEC61800-3 C3 requirements.
External   filters that meet the IEC61800-3 C2 requirements are optional.
