The model code contains information on the VFD. The user can find the model code from the nameplate on the the VFD or from the simplified nameplate.
Figure 3‑5 Model code
Key
Sign
Instruction
Content
Abbreviation
①
Abbreviation
Goodrive35:   Goodrive35 close-loop vector control VFDs
Rated power
②
Power + Load
5R5-5.5   kW
G—constant torque load
Voltage degree
③
Voltage degree
4: AC 3PH 380 V (-15%)–440 V (+10%)
Rated voltage: 380 V
6: AC 3PH 520 V (-15%)–690 V (+10%)
Rated voltage: 660 V
Lot number
④
Lot number
C1: Support 24 V   incremental encoder
D1: Support rotary   transformer
Optional PG cards with   functions of pulse and direction pulse input reference
H1: Support 5 V/12 V   incremental encoder, differential, push-pull, and open collector signals;
Pulse + direction   pulse input reference
H2: Support 5 V   incremental encoder for high-speed differential signal processing;
Pulse + direction   pulse input reference (specific for machine tools)
S1: Support sin/cos encoder, sin/cos (1 Vpp) eg   Heidenhain ERN1387; support quadrature pulse input
