3.6.1 Rated value of AC 3PH 380 V (-15%)–440 V (+10%)
Model
Output    power (kW)
Input    current (A)
Output    current (A)
Carrier    frequency (kHz)
GD35-1R5G-4-C1/D1/H1
1.5
5.0
3.7
1–15 (8)
GD35-2R2G-4-C1/D1/H1
2.2
5.8
5
1–15 (8)
GD35-004G-4-C1/D1/H1/H2/S1
4
13.5
9.5
1–15 (8)
GD35-5R5G-4-C1/D1/H1/H2/S1
5.5
19.5
14
1–15 (8)
GD35-7R5G-4-C1/D1/H1/H2/S1
7.5
25
18.5
1–15 (8)
GD35-011G-4-C1/D1/H1/H2/S1
11
32
25
1–1s5 (8)
GD35-015G-4-C1/D1/H1/H2/S1
15
40
32
1–15 (4)
GD35-018G-4-C1/D1/H1/H2/S1
18.5
47
38
1–15 (4)
GD35-022G-4-C1/D1/H1/H2/S1
22
56
45
1–15 (4)
GD35-030G-4-C1/D1/H1/H2/S1
30
70
60
1–15 (4)
GD35-037G-4-C1/D1/H1/S1
37
80
75
1–15 (4)
GD35-045G-4-C1/D1/H1/S1
45
94
92
1–15 (4)
GD35-055G-4-C1/D1/H1/S1
55
128
115
1–15 (4)
GD35-075G-4-C1/D1/H1/S1
75
160
150
1–15 (2)
GD35-090G-4-C1/D1/H1/S1
90
190
180
1–15 (2)
GD35-110G-4-C1/D1/H1/S1
110
225
215
1–15 (2)
GD35-132G-4-C1/D1/H1/S1
132
265
260
1–15 (2)
GD35-160G-4-C1/D1/H1/S1
160
310
305
1–15 (2)
GD35-185G-4-C1/D1/H1/S1
185
345
340
1–15 (2)
GD35-200G-4-C1/D1/H1/S1
200
385
380
1–15 (2)
GD35-220G-4-C1/D1/H1/S1
220
430
425
1–15 (2)
GD35-250G-4-C1/D1/H1/S1
250
485
480
1–15 (2)
GD35-280G-4-C1/D1/H1/S1
280
545
530
1–15 (2)
GD35-315G-4-C1/D1/H1/S1
315
610
600
1–15 (2)
1. The input current of VFDs 1.5–315 kW is detected when the input voltage is 380 V and there is no DC reactors and input/output reactors.
2. The rated output current is defined when the output voltage is 380 V.
3. The output current cannot exceed the rated output current and the output power cannot exceed the rated output power in the voltage range.
3.6.2 Rated value of AC 3PH 520 V (-15%)–690 V (+10%)
Model
Output    power (kW)
Input    current (A)
Output    current (A)
Carrier frequency
 ( kHz)
GD35-022G-6-C1/D1/H1
22
35
27
1–15 (4)
GD35-030G-6-C1/D1/H1
30
40
34
1–15 (4)
GD35-037G-6-C1/D1/H1
37
47
42
1–15 (4)
GD35-045G-6-C1/D1/H1
45
52
54
1–15 (4)
GD35-055G-6-C1/D1/H1
55
65
62
1–15 (4)
GD35-075G-6-C1/D1/H1
75
85
86
1–15 (2)
GD35-090G-6-C1/D1/H1
90
95
95
1–15 (2)
GD35-110G-6-C1/D1/H1
110
118
131
1–15 (2)
GD35-132G-6-C1/D1/H1
132
145
147
1–15 (2)
GD35-160G-6-C1/D1/H1
160
165
163
1–15 (2)
GD35-185G-6-C1/D1/H1
185
190
198
1–15 (2)
GD35-200G-6-C1/D1/H1
200
210
216
1–15 (2)
GD35-220G-6-C1/D1/H1
220
230
240
1–15 (2)
GD35-250G-6-C1/D1/H1
250
255
274
1–15 (2)
GD35-280G-6-C1/D1/H1
280
286
300
1–15 (2)
GD35-315G-6-C1/D1/H1
315
334
328
1–15 (2)
GD35-350G-6-C1/D1/H1
350
360
380
1–15 (2)
GD35-400G-6-C1/D1/H1
400
411
426
1–15 (2)
GD35-500G-6-C1/D1/H1
500
518
540
1–15 (2)
GD35-560G-6-C1/D1/H1
560
578
600
1–15 (2)
GD35-630G-6-C1/D1/H1
630
655
680
1–15 (2)
1. The input current of VFDs 22–350 kW is detected when the input voltage is 660 V and there is no DC reactors and input/output reactors.
2. The input current of VFDs 400–630 kW is detected when the input voltage is 660 V and there are input reactors.
3. The rated output current is defined when the output voltage is 660 V.
4. The output current cannot exceed the rated output current and the output power cannot exceed the rated output power in the voltage range.
